| tx_metadata_t (void) | |
Public Attributes | |
| bool | has_time_spec |
| time_spec_t | time_spec |
| When to send the first sample.  More... | |
| bool | start_of_burst |
| Set start of burst to true for the first packet in the chain.  More... | |
| bool | end_of_burst |
| Set end of burst to true for the last packet in the chain.  More... | |
| size_t * | eov_positions = nullptr |
| size_t | eov_positions_size = 0 |
TX metadata structure for describing received IF data. Includes time specification, and start and stop burst flags. The send routines will convert the metadata to IF data headers.
| uhd::tx_metadata_t::tx_metadata_t | ( | void | ) |
The default constructor: Sets the fields to default values (flags set to false).
| bool uhd::tx_metadata_t::end_of_burst |
| size_t* uhd::tx_metadata_t::eov_positions = nullptr |
If this pointer is not null, it specifies the address of an array of size_ts specifying the sample offset relative to the beginning of the call to send() where an EOV should be signalled.
The caller is responsible for allocating and deallocating the storage for the array and for indicating the maximum number of elements in the array via the eov_positions_size value below.
| size_t uhd::tx_metadata_t::eov_positions_size = 0 |
| bool uhd::tx_metadata_t::has_time_spec |
Has time specification?
| bool uhd::tx_metadata_t::start_of_burst |
| time_spec_t uhd::tx_metadata_t::time_spec |
