uhd::device Class Referenceabstract
#include <uhd/device.hpp>
Inheritance diagram for uhd::device:
enum  device_filter_t { ANY , USRP , CLOCK }
 Device type, used as a filter in make. More...
typedef std::shared_ptr< devicesptr
typedef std::function< device_addrs_t(const device_addr_t &)> find_t
typedef std::function< sptr(const device_addr_t &)> make_t
virtual ~device (void)=0
 Make a new receive streamer from the streamer arguments. More...
 Make a new transmit streamer from the streamer arguments. More...
uhd::property_tree::sptr get_tree (void) const
 Get access to the underlying property structure. More...
device_filter_t get_device_type () const
 Get device type. More...
static void register_device (const find_t &find, const make_t &make, const device_filter_t filter)
static device_addrs_t find (const device_addr_t &hint, device_filter_t filter=ANY)
 Find devices attached to the host. More...
static sptr make (const device_addr_t &hint, device_filter_t filter=ANY, size_t which=0)
 Create a new device from the device address hint. More...
Protected Attributes
uhd::property_tree::sptr _tree
device_filter_t _type
The device interface represents the hardware. The API allows for discovery, configuration, and streaming.
◆ find_t
typedef std::function<device_addrs_t(const device_addr_t&)> uhd::device::find_t
◆ make_t
typedef std::function<sptr(const device_addr_t&)> uhd::device::make_t
typedef std::shared_ptr<device> uhd::device::sptr
◆ device_filter_t
Enumerator
ANY
USRP
CLOCK
◆ ~device()
virtual uhd::device::~device ( void  )
◆ find()
static device_addrs_t uhd::device::find ( const device_addr_t hint,
device_filter_t  filter = ANY
The hint device address should be used to narrow down the search to particular transport types and/or transport arguments.
hinta partially (or fully) filled in device address
filteran optional filter to exclude USRP or clock devices
a vector of device addresses for all devices on the system
◆ get_device_type()
device_filter_t uhd::device::get_device_type ( ) const
Get device type.
◆ get_rx_stream()
virtual rx_streamer::sptr uhd::device::get_rx_stream ( const stream_args_t args)
Note: There can always only be one streamer. When calling get_rx_stream() a second time, the first streamer must be destroyed beforehand.
◆ get_tree()
uhd::property_tree::sptr uhd::device::get_tree ( void  ) const
◆ get_tx_stream()
virtual tx_streamer::sptr uhd::device::get_tx_stream ( const stream_args_t args)
Note: There can always only be one streamer. When calling get_tx_stream() a second time, the first streamer must be destroyed beforehand.
◆ make()
static sptr uhd::device::make ( const device_addr_t hint,
device_filter_t  filter = ANY,
size_t  which = 0
The method will go through the registered device types and pick one of the discovered devices.
By default, the first result will be used to create a new device. Use the which parameter as an index into the list of results.
whichwhich address to use when multiple are found
a shared pointer to a new device instance
◆ recv_async_msg()
virtual bool uhd::device::recv_async_msg ( async_metadata_t async_metadata,
double  timeout = 0.1
DEPRECATED: Receive asynchronous message from the device
Prefer calling recv_async_msg on the associated TX streamer. This method has the problem that it doesn't necessarily know which Tx streamer is being addressed, and thus might not be delivering the expected outcome.
◆ register_device()
static void uhd::device::register_device ( const find_t find,
const make_t make,
Register a device into the discovery and factory system.
finda function that discovers devices
makea factory function that makes a device
filterinclude only USRP devices, clock devices, or both
◆ _tree
uhd::property_tree::sptr uhd::device::_tree
◆ _type
device_filter_t uhd::device::_type
