◆ strc_payload() [1/3]
| uhd::rfnoc::chdr::strc_payload::strc_payload |
default |
◆ strc_payload() [2/3]
const strc_payload & |
rhs | ) |
default |
◆ strc_payload() [3/3]
strc_payload && |
rhs | ) |
default |
◆ deserialize() [1/2]
| void uhd::rfnoc::chdr::strc_payload::deserialize |
const uint64_t * |
buff, |
size_t |
buff_size |
inline |
Deserialize the payload from a uint64_t buffer (no conversion function)
- Parameters
| buff | Buffer to deserialize the payload from |
| buff_size | Number of elements in the buffer |
◆ deserialize() [2/2]
const uint64_t * |
buff, |
size_t |
buff_size, |
const std::function< uint64_t(uint64_t)> & |
conv_byte_order |
- Parameters
| conv_byte_order | Byte order converter function (buffer to host endianness) |
◆ get_length()
| size_t uhd::rfnoc::chdr::strc_payload::get_length |
const |
Get the serialized size of this payload in 64 bit words.
◆ operator!=()
| bool uhd::rfnoc::chdr::strc_payload::operator!= |
rhs | ) |
const |
inline |
◆ operator=()
◆ operator==()
| bool uhd::rfnoc::chdr::strc_payload::operator== |
rhs | ) |
const |
◆ populate_header()
| void uhd::rfnoc::chdr::strc_payload::populate_header |
chdr_header & |
header | ) |
const |
Populate the header for this type of packet.
◆ serialize() [1/2]
| size_t uhd::rfnoc::chdr::strc_payload::serialize |
uint64_t * |
buff, |
size_t |
max_size_bytes |
| const |
inline |
Serialize the payload to a uint64_t buffer (no conversion function)
◆ serialize() [2/2]
uint64_t * |
buff, |
size_t |
max_size_bytes, |
conv_byte_order |
| const |
Serialize the payload to a uint64_t buffer.
◆ to_string()
| const std::string uhd::rfnoc::chdr::strc_payload::to_string |
const |
Return a string representation of this object.
◆ MAX_PACKET_SIZE
| constexpr size_t uhd::rfnoc::chdr::strc_payload::MAX_PACKET_SIZE = 128 |
staticconstexpr |
Worst-case size of a strc packet (including header)
◆ num_bytes
| uint64_t uhd::rfnoc::chdr::strc_payload::num_bytes = 0 |
Number of bytes to use for operation (64 bits)
◆ num_pkts
| uint64_t uhd::rfnoc::chdr::strc_payload::num_pkts = 0 |
Number of packets to use for operation (40 bits)
◆ op_code
Operation code for the command (4 bits)
◆ op_data
| uint8_t uhd::rfnoc::chdr::strc_payload::op_data = 0 |
Data associated with the operation (4 bits)
◆ src_epid
| uint16_t uhd::rfnoc::chdr::strc_payload::src_epid = 0 |
The source EPID for the stream (16 bits)
