| virtual double | set_freq (const double freq, const size_t chan, const boost::optional< uhd::time_spec_t > time=boost::none)=0 |
| virtual double | get_freq (const size_t chan) const =0 |
| virtual uhd::freq_range_t | get_frequency_range (const size_t chan) const =0 |
| virtual double | get_input_rate (const size_t chan) const =0 |
| virtual void | set_input_rate (const double rate, const size_t chan)=0 |
| virtual double | get_output_rate (const size_t chan) const =0 |
| virtual uhd::meta_range_t | get_output_rates (const size_t chan) const =0 |
| virtual double | set_output_rate (const double rate, const size_t chan)=0 |
| virtual void | issue_stream_cmd (const uhd::stream_cmd_t &stream_cmd, const size_t port)=0 |
| | ~noc_block_base () override |
| | Unique ID for an RFNoC block is its block ID. More...
| | Number of input ports. Note: This gets passed into this block from the. More...
| | Number of output ports. Note: This gets passed outto this block from the. More...
| | Return a reference to this block's subtree. More...
| | Return a reference to this block's subtree (non-const version) More...
| | node_t () |
| | Return a unique identifier string for this node. In every RFNoC graph,. More...
| template<typename prop_data_t > |
| | register_iface_holder (register_iface::sptr reg) |
| | Opaque pointer to the constructor arguments. More...
| enum class | forwarding_policy_t {
ONE_TO_ONE
, ONE_TO_FAN
, ONE_TO_ALL_IN
, ONE_TO_ALL_OUT
ONE_TO_ALL
, DROP
, USE_MAP
| | Types of property/action forwarding for those not defined by the block itself. More...
| | noc_block_base (make_args_ptr make_args) |
| | Update number of input ports. More...
| | Update number of output ports. More...
| | A dirtifyer object, useful for properties that always need updating. More...
DDC Block Control Class
The DDC Block is a multi-channel digital downconverter (DDC) with built-in frequency shift. The number of channels as well as the maximum decimation is configurable in the FPGA, the block controller will read out registers to identify the capabilities of this block.
freq: The frequency shift at the input. Note: A convenience method set_freq() is provided to set this property. It also takes care of the command time, which set_property() does not, and thus should be preferred.
decim: The decimation value
| virtual double uhd::rfnoc::ddc_block_control::set_freq |
const double |
freq, |
const size_t |
chan, |
const boost::optional< uhd::time_spec_t > |
time = boost::none |
Set the DDS frequency
- Parameters
| freq | The frequency shift in Hz |
| chan | The channel to which this change shall be applied |
| time | When to apply the new frequency |
- Returns
- The coerced, actual current frequency of the DDS
