| virtual void | set_alpha (const double alpha, const size_t chan)=0 |
| virtual double | get_alpha (const size_t chan) const =0 |
| virtual void | set_beta (const double beta, const size_t chan)=0 |
| virtual double | get_beta (const size_t chan) const =0 |
| virtual void | set_delay (const uint16_t delay, const size_t chan)=0 |
| virtual uint16_t | get_delay (const size_t chan) const =0 |
| virtual uint16_t | get_max_delay (const size_t chan) const =0 |
| | ~noc_block_base () override |
| | Unique ID for an RFNoC block is its block ID. More...
| | Number of input ports. Note: This gets passed into this block from the. More...
| | Number of output ports. Note: This gets passed outto this block from the. More...
| | Return a reference to this block's subtree. More...
| | Return a reference to this block's subtree (non-const version) More...
| | node_t () |
| | Return a unique identifier string for this node. In every RFNoC graph,. More...
| template<typename prop_data_t > |
| | register_iface_holder (register_iface::sptr reg) |
| | Opaque pointer to the constructor arguments. More...
| enum class | forwarding_policy_t {
ONE_TO_ONE
, ONE_TO_FAN
, ONE_TO_ALL_IN
, ONE_TO_ALL_OUT
ONE_TO_ALL
, DROP
, USE_MAP
| | Types of property/action forwarding for those not defined by the block itself. More...
| | noc_block_base (make_args_ptr make_args) |
| | Update number of input ports. More...
| | Update number of output ports. More...
| | A dirtifyer object, useful for properties that always need updating. More...
Vector IIR Block Control Class
The Vector IIR Block is an RFNoC block that implements an infinite impulse filter with a variable length delay line. The transfer function is defined as follows:
beta
H(z) = ---------------------— 1 - alpha * z ^ -delay
where
- beta is the feedforward tap
- alpha is the feedback tap
- delay (a.k.a. vector length) is the feedback tap delay
