Loading [MathJax]/jax/output/HTML-CSS/config.js
uhd::tx_metadata_t Struct Reference
 tx_metadata_t (void)
Public Attributes
bool has_time_spec
time_spec_t time_spec
 When to send the first sample. More...
bool start_of_burst
 Set start of burst to true for the first packet in the chain. More...
bool end_of_burst
 Set end of burst to true for the last packet in the chain. More...
size_t * eov_positions = nullptr
size_t eov_positions_size = 0
TX metadata structure for describing received IF data. Includes time specification, and start and stop burst flags. The send routines will convert the metadata to IF data headers.
◆ tx_metadata_t()
uhd::tx_metadata_t::tx_metadata_t ( void  )
The default constructor: Sets the fields to default values (flags set to false).
◆ end_of_burst
bool uhd::tx_metadata_t::end_of_burst
◆ eov_positions
size_t* uhd::tx_metadata_t::eov_positions = nullptr
If this pointer is not null, it specifies the address of an array of size_ts specifying the sample offset relative to the beginning of the call to send() where an EOV should be signalled.
The caller is responsible for allocating and deallocating the storage for the array and for indicating the maximum number of elements in the array via the eov_positions_size value below.
◆ eov_positions_size
size_t uhd::tx_metadata_t::eov_positions_size = 0
◆ has_time_spec
bool uhd::tx_metadata_t::has_time_spec
Has time specification?
  • Set false to send immediately.
  • Set true to send at the time specified by time spec.
◆ start_of_burst
bool uhd::tx_metadata_t::start_of_burst
◆ time_spec
time_spec_t uhd::tx_metadata_t::time_spec
