uhd::features::gpio_power_iface Class Referenceabstract
#include <uhd/features/gpio_power_iface.hpp>
Inheritance diagram for uhd::features::gpio_power_iface:
uhd::features::discoverable_feature
using sptr = std::shared_ptr< gpio_power_iface >
- Public Types inherited from uhd::features::discoverable_feature
enum  feature_id_t {
  RESERVED0, RESERVED1, FPGA_LOAD_NOTIFICATION, ADC_SELF_CALIBRATION,
  REF_CLK_CALIBRATION, TRIG_IO_MODE, GPIO_POWER, SPI_GETTER_IFACE
 An enum of all features supported by the driver. When creating a new. More...
using sptr = std::shared_ptr< discoverable_feature >
std::string get_feature_name () const
 Returns a human-readable string name of this feature. More...
virtual ~gpio_power_iface ()=default
virtual std::vector< std::string > get_supported_voltages (const std::string &port) const =0
virtual void set_port_voltage (const std::string &port, const std::string &voltage)=0
virtual std::string get_port_voltage (const std::string &port) const =0
virtual void set_external_power (const std::string &port, bool enable)=0
virtual std::string get_external_power_status (const std::string &port) const =0
- Public Member Functions inherited from uhd::features::discoverable_feature
virtual ~discoverable_feature ()=default
static discoverable_feature::feature_id_t get_feature_id ()
Interface to provide access to configuring the voltage level and external power export configurations of GPIO banks.
◆ ~gpio_power_iface()
virtual uhd::features::gpio_power_iface::~gpio_power_iface ( )
virtualdefault
◆ get_external_power_status()
virtual std::string uhd::features::gpio_power_iface::get_external_power_status ( const std::string &  port) const
Retrieve the status of the external power on the given port. The status can be one of three values: "OFF" - External power is disabled (the default) "ON" - External power is on and functioning normally "FAULT" - The external power supply has encountered a fault condition.
portPort to retrieve status from
◆ get_feature_id()
static discoverable_feature::feature_id_t uhd::features::gpio_power_iface::get_feature_id ( )
inlinestatic
◆ get_feature_name()
std::string uhd::features::gpio_power_iface::get_feature_name ( ) const
Implements uhd::features::discoverable_feature.
◆ get_port_voltage()
virtual std::string uhd::features::gpio_power_iface::get_port_voltage ( const std::string &  port) const
Gets the current I/O voltage level that the port is set to.
portPort to retrieve the voltage level for
The voltage level for the given port
◆ get_supported_voltages()
virtual std::vector<std::string> uhd::features::gpio_power_iface::get_supported_voltages ( const std::string &  port) const
Return what I/O voltage levels are supported on the given port. Voltages use a V in place of the decimal point - typical values include "1V8" for 1.8 volts, "3V3" for 3.3 volts, et cetera.
portPort to list supported voltages for.
A vector of supported voltage levels.
◆ set_external_power()
virtual void uhd::features::gpio_power_iface::set_external_power ( const std::string &  port,
bool  enable
Enables or disables the power supply exposed through the GPIO ports. The GPIO lines will function without external power enabled - the power supply is simply to provide a means for external circuitry to receive power from the device. See your device's documentation for more information on the voltage and current specifications of the external power supply.
portThe port to export power through.
enabletrue to enable power, false to disable.
◆ set_port_voltage()
virtual void uhd::features::gpio_power_iface::set_port_voltage ( const std::string &  port,
const std::string &  voltage
Set the I/O voltage on the given port to the given value.
portPort to set the voltage on.
voltageVoltage level to set. See get_supported_voltages for a list of supported voltages.
