Version: 4.3.0.HEAD-0-g1f8fd345
19 #define RFNOC_BLOCK_CONSTRUCTOR(CLASS_NAME) \
20 CLASS_NAME##_impl(make_args_ptr make_args) : CLASS_NAME(std::move(make_args))
22 #define RFNOC_DECLARE_BLOCK(CLASS_NAME) \
23 using sptr = std::shared_ptr<CLASS_NAME>; \
24 CLASS_NAME(make_args_ptr make_args) : noc_block_base(std::move(make_args)) {}
26 namespace uhd {
namespace rfnoc {
48 using sptr = std::shared_ptr<noc_block_base>;
64 return get_block_id().to_string();
75 return _num_input_ports;
86 return _num_output_ports;
114 double get_tick_rate()
const;
147 size_t get_chdr_hdr_len(
const bool account_for_ts =
true)
const;
176 size_t get_max_payload_size(
209 std::shared_ptr<mb_controller> get_mb_controller();
223 void set_num_input_ports(
const size_t num_ports);
237 void set_num_output_ports(
244 void set_tick_rate(
const double tick_rate);
274 void set_mtu_forwarding_policy(
const forwarding_policy_t policy);
311 virtual void deinit();
314 friend class block_initializer;
321 void _set_tick_rate(
328 void shutdown()
override;
351 size_t _num_input_ports;
354 size_t _num_output_ports;
358 std::vector<property_t<double>> _tick_rate_props;
364 bool _mtu_fwd_policy_set =
false;
368 std::vector<property_t<size_t>> _mtu_props;
371 std::unordered_map<res_source_info, size_t> _mtu;
377 std::shared_ptr<clock_iface> _ctrlport_clock_iface;
380 std::shared_ptr<clock_iface> _tb_clock_iface;
384 std::shared_ptr<mb_controller> _mb_controller;
uhd::device_addr_t get_block_args() const
Definition: noc_block_base.hpp:181
Definition: res_source_info.hpp:17
const block_id_t & get_block_id() const
Definition: noc_block_base.hpp:105
Definition: block_id.hpp:39
Definition: register_iface_holder.hpp:18
Definition: noc_block_base.hpp:42
Definition: noc_block_make_args.hpp:24
Definition: config.h:87
Definition: property_tree.hpp:222
uhd::property_tree::sptr & get_tree()
Return a reference to this block's subtree (non-const version)
Definition: noc_block_base.hpp:193
Definition: device_addr.hpp:37
std::string get_unique_id() const override
Unique ID for an RFNoC block is its block ID.
Definition: noc_block_base.hpp:62
size_t get_num_output_ports() const override
Number of output ports. Note: This gets passed outto this block from the.
Definition: noc_block_base.hpp:84
Definition: build_info.hpp:12
noc_id_t get_noc_id() const
Definition: noc_block_base.hpp:96
forwarding_policy_t
Types of property/action forwarding for those not defined by the block itself.
Definition: node.hpp:46
size_t get_num_input_ports() const override
Number of input ports. Note: This gets passed into this block from the.
Definition: noc_block_base.hpp:73
Definition: property.hpp:25
uhd::property_tree::sptr & get_tree() const
Return a reference to this block's subtree.
Definition: noc_block_base.hpp:187
Definition: noc_block_base.hpp:48
uint32_t noc_id_t
Definition: defaults.hpp:49
std::unique_ptr< make_args_t > make_args_ptr
Opaque pointer to the constructor arguments.
Definition: noc_block_base.hpp:54
chdr_w_t
Type that indicates the CHDR Width in bits.
Definition: rfnoc_types.hpp:19
