uhd::rfnoc::res_source_info Struct Reference
#include <uhd/rfnoc/res_source_info.hpp>
enum  source_t { USER, INPUT_EDGE, OUTPUT_EDGE, FRAMEWORK }
 res_source_info ()=delete
 res_source_info (source_t source_type, size_t instance_=0)
bool operator== (const res_source_info &rhs) const
bool operator!= (const res_source_info &rhs) const
std::string to_string () const
 Returns a string representation of the source. More...
static source_t invert_edge (const source_t edge_direction)
Public Attributes
source_t type
 The type of source (user or edge) More...
size_t instance = 0
 The instance of the source. For resource that is sourced by a edge, it. More...
Describes the source of a particular resource (property or action)
◆ source_t
Source type
Enumerator
USER
The user API sources this resource.
INPUT_EDGE
An input edge sources this resource.
OUTPUT_EDGE
FRAMEWORK
This is a special resource, only accessed by the framework.
◆ res_source_info() [1/2]
uhd::rfnoc::res_source_info::res_source_info ( )
delete
◆ res_source_info() [2/2]
uhd::rfnoc::res_source_info::res_source_info ( source_t  source_type,
size_t  instance_ = 0
◆ invert_edge()
static source_t uhd::rfnoc::res_source_info::invert_edge ( const source_t  edge_direction)
inlinestatic
Convenience function to invert the type value if it's an edge.
  • Will assert that the edge is actually either INPUT_EDGE or OUTPUT_EDGE
  • Then, returns the opposite of what it was before
Exceptions
uhd::assertion_errorif edge_direction is neither INPUT_EDGE nor OUTPUT_EDGE
◆ operator!=()
bool uhd::rfnoc::res_source_info::operator!= ( const res_source_info rhs) const
◆ operator==()
bool uhd::rfnoc::res_source_info::operator== ( const res_source_info rhs) const
◆ to_string()
std::string uhd::rfnoc::res_source_info::to_string ( ) const
◆ instance
size_t uhd::rfnoc::res_source_info::instance = 0
◆ type
source_t uhd::rfnoc::res_source_info::type
