uhd::tune_request_t Struct Reference
enum  policy_t { POLICY_NONE = int('N'), POLICY_AUTO = int('A'), POLICY_MANUAL = int('M') }
 Policy options for tunable elements in the RF chain. More...
 tune_request_t (double target_freq=0)
 tune_request_t (double target_freq, double lo_off)
Public Attributes
double target_freq
policy_t rf_freq_policy
double rf_freq
policy_t dsp_freq_policy
double dsp_freq
device_addr_t args
A tune request instructs the implementation how to tune the RF chain. The policies can be used to select automatic tuning or fine control over the daughterboard IF and DSP tuning. Not all combinations of policies are applicable. Convenience constructors are supplied for most use cases.
See also Tuning Notes
◆ policy_t
Enumerator
POLICY_NONE
Do not set this argument, use current setting.
POLICY_AUTO
Automatically determine the argument's value.
POLICY_MANUAL
Use the argument's value for the setting.
◆ tune_request_t() [1/2]
uhd::tune_request_t::tune_request_t ( double  target_freq = 0)
Make a new tune request for a particular center frequency. Use an automatic policy for the RF and DSP frequency to tune the chain as close as possible to the target frequency.
target_freqthe target frequency in Hz
◆ tune_request_t() [2/2]
uhd::tune_request_t::tune_request_t ( double  target_freq,
double  lo_off
Make a new tune request for a particular center frequency. Use a manual policy for the RF frequency, and an automatic policy for the DSP frequency, to tune the chain as close as possible to the target frequency.
lo_offthe LO offset frequency in Hz
◆ args
device_addr_t uhd::tune_request_t::args
  • mode_n: Allows the user to tell the daughterboard tune code to choose between an integer N divider or fractional N divider. Default is fractional N on boards that support fractional N tuning. Fractional N provides greater tuning accuracy at the expense of spurs. Possible options for this key: "integer" or "fractional".
◆ dsp_freq
double uhd::tune_request_t::dsp_freq
The DSP frequency in Hz. Set when the policy is set to manual.
Note that the meaning of the DSP frequency's sign differs between TX and RX operations. The target frequency is the result of target_freq = rf_freq + sign * dsp_freq. For TX, sign is negative, and for RX, sign is positive. Example: If both RF and DSP tuning policies are set to manual, and rf_freq is set to 1 GHz, and dsp_freq is set to 10 MHz, the actual target frequency is 990 MHz for a TX tune request, and 1010 MHz for an RX tune request.
◆ dsp_freq_policy
policy_t uhd::tune_request_t::dsp_freq_policy
The policy for the DSP frequency. Automatic behavior: the difference between the target and IF.
◆ rf_freq
double uhd::tune_request_t::rf_freq
The RF frequency in Hz. Set when the policy is set to manual.
◆ rf_freq_policy
policy_t uhd::tune_request_t::rf_freq_policy
The policy for the RF frequency. Automatic behavior: the target frequency + default LO offset.
◆ target_freq
double uhd::tune_request_t::target_freq
The target frequency of the overall chain in Hz. Set this even if all policies are set to manual.
