   17 namespace uhd {
namespace rfnoc {
   24     typedef std::shared_ptr<blockdef>
sptr;
   42         bool is_variable(
const std::string& key)
const;
   44         bool is_keyword(
const;
   47         bool is_valid()
const;
   49         std::string to_string()
const;
   64         bool is_valid()
const;
   66         std::string to_string()
const;
   78     static sptr make_from_noc_id(uint64_t noc_id);
   81     virtual bool is_block()
const = 0;
   84     virtual bool is_component()
const = 0;
   87     virtual std::string get_key()
const = 0;
   90     virtual std::string get_name()
const = 0;
   93     virtual uint64_t noc_id()
const = 0;
   95     virtual ports_t get_input_ports()  = 0;
   96     virtual ports_t get_output_ports() = 0;
   99     virtual std::vector<size_t> get_all_port_numbers() = 0;
  104     virtual args_t get_args() = 0;
std::shared_ptr< blockdef > sptr
Definition: blockdef.hpp:24
std::vector< arg_t > args_t
Definition: blockdef.hpp:68
static const std::set< std::string > VALID_TYPES
Definition: blockdef.hpp:59
Describes arguments in a block definition.
Definition: blockdef.hpp:54
uhd::dict< std::string, size_t > registers_t
Definition: blockdef.hpp:70
static const device_addr_t PORT_ARGS
A list of args a port can have.
Definition: blockdef.hpp:37
Definition: config.h:87
Describes port options for a block definition.
Definition: blockdef.hpp:33
Definition: device_addr.hpp:37
Definition: build_info.hpp:12
Definition: blockdef.hpp:21
static const device_addr_t ARG_ARGS
A list of args an argument can have.
Definition: blockdef.hpp:58
std::vector< port_t > ports_t
Definition: blockdef.hpp:51
