#include <uhd/types/dict.hpp>
| | dict (void) |
| template<typename InputIterator > |
| | dict (InputIterator first, InputIterator last) |
| std::size_t | size (void) const |
| std::vector< Key > | keys (void) const |
| std::vector< Val > | vals (void) const |
| bool | has_key (const Key &key) const |
| const Val & | get (const Key &key, const Val &other) const |
| const Val & | get (const Key &key) const |
| void | set (const Key &key, const Val &val) |
| const Val & | operator[] (const Key &key) const |
| Val & | operator[] (const Key &key) |
| bool | operator== (const dict< Key, Val > &other) const |
| bool | operator!= (const dict< Key, Val > &other) const |
| Val | pop (const Key &key) |
| void | update (const dict< Key, Val > &new_dict, bool fail_on_conflict=true) |
| | operator std::map< Key, Val > () const |
template<typename Key, typename Val>
class uhd::dict< Key, Val >
A templated dictionary class with a python-like interface.
◆ dict() [1/2]
template<typename Key , typename Val >
Create a new empty dictionary.
◆ dict() [2/2]
| uhd::dict< Key, Val >::dict |
InputIterator |
first, |
InputIterator |
last |
Input iterator constructor: Makes boost::assign::map_list_of work.
- Parameters
| first | the begin iterator |
| last | the end iterator |
◆ get() [1/2]
| const Val & uhd::dict< Key, Val >::get |
const Key & |
key | ) |
const |
Get a value in the dict or throw.
- Parameters
- Returns
- the value or default
◆ get() [2/2]
const Key & |
key, |
const Val & |
other |
| const |
Get a value in the dict or default.
- Parameters
| key | the key to look for |
| other | use if key not found |
- Returns
◆ has_key()
| bool uhd::dict< Key, Val >::has_key |
const Key & |
key | ) |
const |
Does the dictionary contain this key?
- Parameters
- Returns
- true if found
◆ keys()
| std::vector< Key > uhd::dict< Key, Val >::keys |
void |
const |
Get a list of the keys in this dict. Key order depends on insertion precedence.
- Returns
- vector of keys
◆ operator std::map< Key, Val >()
| uhd::dict< Key, Val >::operator std::map< Key, Val > |
Typecast operator to std::map<>
◆ operator!=()
| bool uhd::dict< Key, Val >::operator!= |
const dict< Key, Val > & |
other | ) |
const |
Not equal operator for the dict type
- Parameters
| other | the dict being compared to this |
- Returns
- whether or not the two dict's are not equal
◆ operator==()
| bool uhd::dict< Key, Val >::operator== |
other | ) |
const |
Equals operator for the dict type
- Parameters
- Returns
- whether or not the two dict's are equal
◆ operator[]() [1/2]
| Val & uhd::dict< Key, Val >::operator[] |
const Key & |
key | ) |
Set a value for the given key, however, in reality it really returns a reference which can be assigned to.
- Parameters
- Returns
- a reference to the value
◆ operator[]() [2/2]
| const Val & uhd::dict< Key, Val >::operator[] |
const Key & |
key | ) |
const |
Get a value for the given key if it exists. If the key is not found throw an error.
- Parameters
- Returns
- the value at the key
- Exceptions
| an | exception when not found |
◆ pop()
| Val uhd::dict< Key, Val >::pop |
const Key & |
key | ) |
Pop an item out of the dictionary.
- Parameters
- Returns
- the value of the item
- Exceptions
◆ set()
| void uhd::dict< Key, Val >::set |
const Key & |
key, |
const Val & |
val |
Set a value in the dict at the key.
- Parameters
| key | the key to set at |
| val | the value to set |
◆ size()
| std::size_t uhd::dict< Key, Val >::size |
void |
const |
Get the number of elements in this dict.
- Returns
- the number of elements
◆ update()
| void uhd::dict< Key, Val >::update |
new_dict, |
bool |
fail_on_conflict = true |
Update this dictionary with values from another.
Basically, this copies all the key/value pairs from new_dict into this dict. When the key is already present in the current dict, it either overwrites the current value (if fail_on_conflict is false) or it throws (if fail_on_conflict is true and the values differ).
With the exception of fail_on_conflict, this behaves analogously to Python's dict.update() method.
- Parameters
| new_dict | The arguments to copy. |
| fail_on_conflict | If true, throws. |
- Exceptions
◆ vals()
| std::vector< Val > uhd::dict< Key, Val >::vals |
void |
const |
Get a list of the values in this dict. Value order depends on insertion precedence.
- Returns
- vector of values
