uhd::image_loader Class Reference
#include <uhd/image_loader.hpp>
Inheritance diagram for uhd::image_loader:
Classes
struct  image_loader_args_t
typedef std::function< bool(const image_loader_args_t &)> loader_fcn_t
 Signature of an image loading function. More...
static void register_image_loader (const std::string &device_type, const loader_fcn_t &loader_fcn, const std::string &recovery_instructions)
 Register an image loader. More...
static bool load (const image_loader_args_t &image_loader_args)
 Load firmware and/or FPGA onto a device. More...
static std::string get_recovery_instructions (const std::string &device_type)
 Get the instructions on how to recovery a particular device. More...
◆ loader_fcn_t
typedef std::function<bool(const image_loader_args_t&)> uhd::image_loader::loader_fcn_t
This is the function signature for an image loading function. See the declaration of load() for the meaning of these arguments.
This function must return true upon the end of a successful image load or false if no applicable device was found. It may only throw a runtime error under one of three conditions:
  • The function finds multiple devices that fit the user's arguments.
  • The function has already engaged with a specific device and something goes wrong.
  • The user gives arguments that unambiguously lead to a specific device and expect the default image(s) to be loaded, but the specific model of the device cannot be determined beyond a category.
◆ get_recovery_instructions()
static std::string uhd::image_loader::get_recovery_instructions ( const std::string &  device_type)
These instructions should be queried if the user interrupts an image loading session, as this will likely leave the device in an unstable state.
device_typethe "type=foo" value given in an –args option
recovery instructions
◆ load()
static bool uhd::image_loader::load ( const image_loader_args_t image_loader_args)
image_loader_argsarguments to pass into image loading function
◆ register_image_loader()
static void uhd::image_loader::register_image_loader ( const std::string &  device_type,
const loader_fcn_t loader_fcn,
const std::string &  recovery_instructions
loader_fcnthe loader function for the given device
recovery_instructionsinstructions on how to restore a device
