#include <uhd/rfnoc/window_block_control.hpp>
| virtual size_t | get_max_num_coefficients (const size_t chan) const =0 |
| virtual void | set_coefficients (const std::vector< int16_t > &coeffs, const size_t chan)=0 |
| virtual std::vector< int16_t > | get_coefficients (const size_t chan) const =0 |
| Number of input ports. Note: This gets passed into this block from the. More... | |
| Number of output ports. Note: This gets passed outto this block from the. More... | |
| static const uint32_t | REG_WINDOW_BLOCK_SIZE |
| static const uint32_t | REG_WINDOW_LEN_OFFSET |
| static const uint32_t | REG_WINDOW_MAX_LEN_OFFSET |
| static const uint32_t | REG_WINDOW_LOAD_COEFF_OFFSET |
| static const uint32_t | REG_WINDOW_LOAD_COEFF_LAST_OFFSET |
| Update number of input ports. More... | |
| Update number of output ports. More... | |
Window Block Control Class
The Window Block is a windowing block for RFNoC that is intended to be used with the FFT block. The block can be configured with coefficients, by which the samples in each input packet are multiplied before begin output. The first sample of the first packet is multiplied by the first first coefficient, the second sample is multiplied by the second coefficient, and so on.
The RFNoC window block supports a configurable number of pairs of input and output ports of sc16 data (16-bit fixed-point complex samples) and a configurable window length and coefficients for each.
Get the window coefficients
Return a vector with the current window coefficients for a given channel.
| chan | The channel to retrieve the current window coefficients from |
Get the maximum number of window coefficients supported by this block
Get the maximum number of window coefficients supported by this block.
| chan | The channel to retrieve the maximum number of coefficients from |
Set the window coefficients
Set the window coefficients for a given channel. The number of coefficients must be equal to or less than the maximum number of coefficients supported by the given channel of the block.
| coeffs | A vector of integer coefficients for the window |
| chan | The channel to apply the coefficients to |
