uhd::usrp::cal::iq_cal Class Referenceabstract
#include <uhd/cal/iq_cal.hpp>
Inheritance diagram for uhd::usrp::cal::iq_cal:
uhd::usrp::cal::container
using sptr = std::shared_ptr< iq_cal >
virtual void set_interp_mode (const uhd::math::interp_mode interp)=0
 Choose interpolation mode. More...
virtual std::complex< double > get_cal_coeff (const double freq) const =0
 Return a calibration coefficient for a given frequency. More...
virtual void set_cal_coeff (const double freq, const std::complex< double > coeff, const double suppression_abs=0, const double suppression_delta=0)=0
 Update / set a calbration coefficient. More...
virtual void clear ()=0
 Clear the list of coefficients. More...
- Public Member Functions inherited from uhd::usrp::cal::container
virtual ~container ()=default
virtual std::string get_name () const =0
 Return the name of this calibration table. More...
virtual std::string get_serial () const =0
 Return the device serial of this calibration table. More...
virtual uint64_t get_timestamp () const =0
 Timestamp of acquisition time. More...
virtual std::vector< uint8_t > serialize ()=0
 Return a serialized version of this container. More...
virtual void deserialize (const std::vector< uint8_t > &data)=0
 Populate this class from the serialized data. More...
static sptr make (const std::string &name, const std::string &serial, const uint64_t timestamp)
 Factory for new cal data sets. More...
static sptr make ()
 Default factory. More...
- Static Public Member Functions inherited from uhd::usrp::cal::container
template<typename container_type >
static std::shared_ptr< container_type > make (const std::vector< uint8_t > &data)
 Generic factory for cal data from serialized data. More...
Class that stores IQ cal data per frequency
The following calibrations use this:
  • Gen-2 and Gen-3 TX DC Offset
  • Gen-2 and Gen-3 RX,TX IQ Imbalance
using uhd::usrp::cal::iq_cal::sptr = std::shared_ptr<iq_cal>
◆ clear()
virtual void uhd::usrp::cal::iq_cal::clear ( )
◆ get_cal_coeff()
virtual std::complex<double> uhd::usrp::cal::iq_cal::get_cal_coeff ( const double  freq) const
◆ make() [1/2]
static sptr uhd::usrp::cal::iq_cal::make ( )
Default factory.
◆ make() [2/2]
static sptr uhd::usrp::cal::iq_cal::make ( const std::string &  name,
const std::string &  serial,
◆ set_cal_coeff()
virtual void uhd::usrp::cal::iq_cal::set_cal_coeff ( const double  freq,
const double  suppression_abs = 0,
const double  suppression_delta = 0
◆ set_interp_mode()
virtual void uhd::usrp::cal::iq_cal::set_interp_mode ( const uhd::math::interp_mode  interp)
