   16 namespace uhd {
namespace rfnoc {
namespace rf_control {
   28     using sptr = std::shared_ptr<core_iface>;
   42     virtual std::vector<std::string>
get_tx_antennas(
const size_t chan)
const = 0;
   48     virtual void set_tx_antenna(
const std::string& ant,
const size_t chan) = 0;
   60     virtual std::vector<std::string>
get_rx_antennas(
const size_t chan)
const = 0;
   66     virtual void set_rx_antenna(
  140         const std::string& name,
const size_t chan)
const = 0;
  152     virtual double get_tx_gain(
  164     virtual double set_tx_gain(
const double gain,
  174         const double gain,
  187         const std::string& name,
const size_t chan)
const = 0;
  199     virtual double get_rx_gain(
  208     virtual double set_rx_gain(
const double gain,
  218         const double gain,
  224     virtual void set_rx_agc(
const bool enable,
  242     virtual double set_tx_bandwidth(
const double bandwidth,
  260     virtual double set_rx_bandwidth(
  270     virtual std::vector<std::string>
get_rx_lo_names(
const size_t chan)
const = 0;
  281         const std::string& name,
const size_t chan)
const = 0;
  292         const std::string& name,
const size_t chan)
const = 0;
  304         const std::string& src,
  315         const std::string& name,
  326         bool enabled,
  343         double freq,
  353     virtual double get_rx_lo_freq(
  360     virtual std::vector<std::string>
get_tx_lo_names(
const size_t chan)
const = 0;
  371         const std::string& name,
const size_t chan)
const = 0;
  382         const std::string& name,
  394         const std::string& src,
  405         const std::string& name,
  416         const bool enabled,
  435         const double freq,
  448     virtual double get_tx_lo_freq(
virtual std::vector< std::string > get_rx_lo_names(const size_t chan) const =0
virtual void set_rx_antenna(const std::string &ant, const size_t chan)=0
virtual double set_tx_bandwidth(const double bandwidth, const size_t chan)=0
virtual uhd::freq_range_t get_rx_frequency_range(const size_t chan) const =0
virtual std::string get_rx_antenna(const size_t chan) const =0
virtual void set_tx_tune_args(const uhd::device_addr_t &args, const size_t chan)=0
virtual double set_rx_frequency(const double freq, const size_t chan)=0
virtual void set_tx_lo_export_enabled(const bool enabled, const std::string &name, const size_t chan)=0
virtual const std::string get_rx_lo_source(const std::string &name, const size_t chan)=0
virtual double set_rx_bandwidth(const double bandwidth, const size_t chan)=0
virtual std::vector< std::string > get_rx_gain_names(const size_t chan) const =0
virtual void set_tx_lo_source(const std::string &src, const std::string &name, const size_t chan)=0
virtual std::vector< std::string > get_rx_lo_sources(const std::string &name, const size_t chan) const =0
virtual double set_tx_lo_freq(const double freq, const std::string &name, const size_t chan)=0
std::shared_ptr< core_iface > sptr
Definition: core_iface.hpp:28
virtual freq_range_t get_tx_lo_freq_range(const std::string &name, const size_t chan)=0
virtual uhd::gain_range_t get_rx_gain_range(const size_t chan) const =0
virtual ~core_iface()=default
virtual bool get_tx_lo_export_enabled(const std::string &name, const size_t chan)=0
Definition: device_addr.hpp:37
virtual const std::string get_tx_lo_source(const std::string &name, const size_t chan)=0
virtual std::string get_tx_antenna(const size_t chan) const =0
virtual uhd::freq_range_t get_tx_frequency_range(const size_t chan) const =0
virtual meta_range_t get_rx_bandwidth_range(size_t chan) const =0
virtual std::vector< std::string > get_rx_antennas(const size_t chan) const =0
Definition: core_iface.hpp:25
virtual uhd::gain_range_t get_tx_gain_range(const size_t chan) const =0
virtual double get_tx_frequency(const size_t chan)=0
Definition: build_info.hpp:12
virtual double get_tx_bandwidth(const size_t chan)=0
virtual void set_rx_tune_args(const uhd::device_addr_t &args, const size_t chan)=0
virtual void set_rx_agc(const bool enable, const size_t chan)=0
virtual double get_rx_frequency(const size_t chan)=0
virtual void set_rx_lo_export_enabled(bool enabled, const std::string &name, const size_t chan)=0
virtual double set_rx_lo_freq(double freq, const std::string &name, const size_t chan)=0
virtual void set_rx_lo_source(const std::string &src, const std::string &name, const size_t chan)=0
virtual double get_rx_gain(const size_t chan)=0
virtual double get_rx_bandwidth(const size_t chan)=0
virtual double set_tx_frequency(const double freq, size_t chan)=0
virtual double set_tx_gain(const double gain, const size_t chan)=0
virtual void set_tx_antenna(const std::string &ant, const size_t chan)=0
virtual std::vector< std::string > get_tx_antennas(const size_t chan) const =0
virtual std::vector< std::string > get_tx_gain_names(const size_t chan) const =0
virtual double get_tx_gain(const size_t chan)=0
virtual bool get_rx_lo_export_enabled(const std::string &name, const size_t chan)=0
virtual double get_tx_lo_freq(const std::string &name, const size_t chan)=0
virtual std::vector< std::string > get_tx_lo_sources(const std::string &name, const size_t chan) const =0
virtual double set_rx_gain(const double gain, const size_t chan)=0
virtual std::vector< std::string > get_tx_lo_names(const size_t chan) const =0
virtual double get_rx_lo_freq(const std::string &name, const size_t chan)=0
virtual meta_range_t get_tx_bandwidth_range(size_t chan) const =0
virtual freq_range_t get_rx_lo_freq_range(const std::string &name, const size_t chan) const =0
