A meta-range object holds a list of individual ranges.
◆ meta_range_t() [1/3]
| uhd::meta_range_t::meta_range_t |
void |
A default constructor for an empty meta-range.
◆ meta_range_t() [2/3]
template<typename InputIterator >
InputIterator |
first, |
InputIterator |
last |
inline |
Input iterator constructor: Makes boost::assign::list_of work.
- Parameters
| first | the begin iterator |
| last | the end iterator |
◆ meta_range_t() [3/3]
double |
start, |
double |
stop, |
double |
step = 0 |
A convenience constructor for a single range. A step size of zero implies infinite precision.
- Parameters
| start | the minimum value for this range |
| stop | the maximum value for this range |
| step | the step size for this range |
◆ as_monotonic()
A method for converting an arbitrary meta_range_t into a monotonic meta_range_t which has no overlapping ranges, and where all ranges are sorted.
Requires that all subranges have a step size of zero, or else it throws uhd::value_error.
- Returns
- a monotonic meta_range_t
◆ clip()
| double uhd::meta_range_t::clip |
double |
value, |
bool |
clip_step = false |
| const |
Clip the target value to a possible range value.
- Parameters
| value | the value to clip to this range |
| clip_step | if true, clip to steps as well |
- Returns
- a value that is in one of the ranges
◆ start()
| double uhd::meta_range_t::start |
void |
const |
Get the overall start value for this meta-range.
◆ step()
| double uhd::meta_range_t::step |
void |
const |
Get the overall step value for this meta-range.
◆ stop()
| double uhd::meta_range_t::stop |
void |
const |
Get the overall stop value for this meta-range.
◆ to_pp_string()
| const std::string uhd::meta_range_t::to_pp_string |
void |
const |
Convert this meta-range to a printable string.
