mboard_eeprom.h File Reference
#include <uhd/config.h>
#include <uhd/error.h>
Typedefs
typedef struct uhd_mboard_eeprom_t * uhd_mboard_eeprom_handle
 A C-level interface for interacting with a USRP motherboard's EEPROM. More...
Functions
UHD_API uhd_error uhd_mboard_eeprom_make (uhd_mboard_eeprom_handle *h)
 Create a handle for working with a USRP motherboard EEPROM. More...
UHD_API uhd_error uhd_mboard_eeprom_free (uhd_mboard_eeprom_handle *h)
 Free a USRP motherboard EEPROM handle. More...
UHD_API uhd_error uhd_mboard_eeprom_get_value (uhd_mboard_eeprom_handle h, const char *key, char *value_out, size_t strbuffer_len)
 Get the value associated with the given EEPROM key. More...
UHD_API uhd_error uhd_mboard_eeprom_set_value (uhd_mboard_eeprom_handle h, const char *key, const char *value)
 Set the value for the given EEPROM key. More...
UHD_API uhd_error uhd_mboard_eeprom_last_error (uhd_mboard_eeprom_handle h, char *error_out, size_t strbuffer_len)
 Get the last error recorded by the handle. More...
Typedef Documentation
◆ uhd_mboard_eeprom_handle
typedef struct uhd_mboard_eeprom_t* uhd_mboard_eeprom_handle
See uhd::usrp::mboard_eeprom_t for more details.
NOTE: Using a handle before passing it into uhd_mboard_eeprom_make() will result in undefined behavior.
Function Documentation
◆ uhd_mboard_eeprom_free()
UHD_API uhd_error uhd_mboard_eeprom_free ( uhd_mboard_eeprom_handle h)
◆ uhd_mboard_eeprom_get_value()
UHD_API uhd_error uhd_mboard_eeprom_get_value ( uhd_mboard_eeprom_handle  h,
const char *  key,
char *  value_out,
◆ uhd_mboard_eeprom_last_error()
UHD_API uhd_error uhd_mboard_eeprom_last_error ( uhd_mboard_eeprom_handle  h,
char *  error_out,
◆ uhd_mboard_eeprom_make()
UHD_API uhd_error uhd_mboard_eeprom_make ( uhd_mboard_eeprom_handle h)
◆ uhd_mboard_eeprom_set_value()
UHD_API uhd_error uhd_mboard_eeprom_set_value ( uhd_mboard_eeprom_handle  h,
const char *  key,
const char *  value
