Loading [MathJax]/jax/input/TeX/config.js
uhd::build_info Namespace Reference
Functions
const UHD_API std::string boost_version ()
 Return the version of Boost this build was built with. More...
const UHD_API std::string build_date ()
 Return the date and time (GMT) this UHD build was built. More...
const UHD_API std::string c_compiler ()
 Return the C compiler used for this build. More...
const UHD_API std::string cxx_compiler ()
 Return the C++ compiler used for this build. More...
const UHD_API std::string c_flags ()
 Return the C flags passed into this build. More...
const UHD_API std::string cxx_flags ()
 Return the C++ flags passed into this build. More...
const UHD_API std::string enabled_components ()
 Return the UHD components enabled for this build, comma-delimited. More...
const UHD_API std::string install_prefix ()
 Return the default CMake install prefix for this build. More...
const UHD_API std::string libusb_version ()
 Return the version of libusb this build was built with. More...
Function Documentation
◆ boost_version()
const UHD_API std::string uhd::build_info::boost_version ( )
◆ build_date()
const UHD_API std::string uhd::build_info::build_date ( )
◆ c_compiler()
const UHD_API std::string uhd::build_info::c_compiler ( )
◆ c_flags()
const UHD_API std::string uhd::build_info::c_flags ( )
◆ cxx_compiler()
const UHD_API std::string uhd::build_info::cxx_compiler ( )
◆ cxx_flags()
const UHD_API std::string uhd::build_info::cxx_flags ( )
◆ enabled_components()
const UHD_API std::string uhd::build_info::enabled_components ( )
◆ install_prefix()
const UHD_API std::string uhd::build_info::install_prefix ( )
◆ libusb_version()
const UHD_API std::string uhd::build_info::libusb_version ( )
