17 namespace uhd {
namespace rfnoc {
    24     typedef std::shared_ptr<blockdef>
sptr;
    42         bool is_variable(
const std::string& key)
const;
    44         bool is_keyword(
const;
    47         bool is_valid()
const;
    49         std::string to_string()
const;
    64         bool is_valid()
const;
    66         std::string to_string()
const;
    78     static sptr make_from_noc_id(uint64_t noc_id);
    81     virtual bool is_block()
const = 0;
    84     virtual bool is_component()
const = 0;
    87     virtual std::string get_key()
const = 0;
    90     virtual std::string get_name()
const = 0;
    93     virtual uint64_t noc_id()
const = 0;
    95     virtual ports_t get_input_ports()  = 0;
    96     virtual ports_t get_output_ports() = 0;
    99     virtual std::vector<size_t> get_all_port_numbers() = 0;
   104     virtual args_t get_args() = 0;
   107     virtual registers_t get_settings_registers() = 0;
   110     virtual registers_t get_readback_registers() = 0;
 Definition: blockdef.hpp:21
uhd::dict< std::string, size_t > registers_t
Definition: blockdef.hpp:70
static const std::set< std::string > VALID_TYPES
Definition: blockdef.hpp:59
std::vector< arg_t > args_t
Definition: blockdef.hpp:68
Definition: build_info.hpp:12
Definition: config.h:87
Describes port options for a block definition.
Definition: blockdef.hpp:33
static const device_addr_t PORT_ARGS
A list of args a port can have.
Definition: blockdef.hpp:37
static const device_addr_t ARG_ARGS
A list of args an argument can have.
Definition: blockdef.hpp:58
Describes arguments in a block definition.
Definition: blockdef.hpp:54
std::shared_ptr< blockdef > sptr
Definition: blockdef.hpp:24
std::vector< port_t > ports_t
Definition: blockdef.hpp:51
Definition: device_addr.hpp:37
