 device_addr_t (const char *args)
 device_addr_t (const std::map< std::string, std::string > &info)
template<typename T >
T cast (const std::string &key, const T &def) const
 dict (void)
std::size_t size (void) const
bool operator== (const dict< std::string, std::string > &other) const
bool operator!= (const dict< std::string, std::string > &other) const
void update (const dict< std::string, std::string > &new_dict, bool fail_on_conflict=true)
 operator std::map< std::string, std::string > () const
  • Ex: addr=192.168.10.2
◆ device_addr_t() [1/3]
argsthe arguments string
◆ device_addr_t() [2/3]
uhd::device_addr_t::device_addr_t ( const char *  args)
◆ device_addr_t() [3/3]
uhd::device_addr_t::device_addr_t ( const std::map< std::string, std::string > &  info)
Create a device address from a std::map
infothe device info map
◆ cast()
const T &  def
) const
Exceptions
◆ to_pp_string()
◆ to_string()
