#include <uhd/stream.hpp>
typedef std::shared_ptr< rx_streamer > sptr
virtual ~rx_streamer (void)
virtual void issue_stream_cmd (const stream_cmd_t &stream_cmd)=0
◆ buffs_type
typedef std::shared_ptr<rx_streamer> uhd::rx_streamer::sptr
◆ ~rx_streamer()
virtual uhd::rx_streamer::~rx_streamer ( void  )
virtual
◆ get_max_num_samps()
◆ get_num_channels()
◆ issue_stream_cmd()
virtual void uhd::rx_streamer::issue_stream_cmd ( const stream_cmd_t &  stream_cmd)
◆ recv()
virtual size_t uhd::rx_streamer::recv ( const buffs_type &  buffs,
rx_metadata_t &  metadata,
const double  timeout = 0.1,
Receive handles fragmentation as follows: If the buffer has insufficient space to hold all samples that were received in a single packet over-the-wire, then the buffer will be completely filled and the implementation will hold a pointer into the remaining portion of the packet. Subsequent calls will load from the remainder of the packet, and will flag the metadata to show that this is a fragment. The next call to receive, after the remainder becomes exhausted, will perform an over-the-wire receive as usual. See the rx metadata fragment flags and offset fields for details.
Note on threading: recv() is not thread-safe, to avoid locking overhead. The application calling recv() is responsible for making sure that not more than one thread can call recv() on the same streamer at the same time. If there are multiple streamers, receiving from different sources, then those may be called from different threads simultaneously.
Error Handling
metadata is a value that is set inside this function (effectively, a return value), and should be checked for potential error codes (see rx_metadata_t::error_code_t).
The most common error code when something goes wrong is an overrun (also referred to as overflow: error_code_t::ERROR_CODE_OVERFLOW). This error code means that the device produced data faster than the application could read, and various buffers filled up leaving no more space for the device to write data to. Note that an overrun on the device will not immediatiely show up when calling recv(). Depending on the device implementation, there may be many more valid samples available before the device had to stop writing samples to the FIFO. Only when all valid samples are returned to the call site will the error code be set to "overrun". When this happens, all valid samples have been returned to application where recv() was called. If the device is streaming continuously, it will reset itself when the FIFO is cleared, and recv() can be called again to retrieve new, valid data.
[out]metadatadata to fill describing the buffer
