12 namespace uhd {
namespace rfnoc {
    19 static const std::string PROP_KEY_MAGNITUDE    =
"magnitude";
    20 static const std::string PROP_KEY_DIRECTION    =
"direction";
    21 static const std::string PROP_KEY_LENGTH       =
"length";
    22 static const std::string PROP_KEY_FFT_SCALING  =
"fft_scaling";
    23 static const std::string PROP_KEY_SHIFT_CONFIG =
"shift_config";
    46     static const uint32_t REG_RESET_ADDR;
    47     static const uint32_t REG_LENGTH_LOG2_ADDR;
    48     static const uint32_t REG_MAGNITUDE_OUT_ADDR;
    49     static const uint32_t REG_DIRECTION_ADDR;
    50     static const uint32_t REG_SCALING_ADDR;
    51     static const uint32_t REG_SHIFT_CONFIG_ADDR;
    60     virtual
void set_direction(const
fft_direction direction) = 0;
    81     virtual
void set_magnitude(const
fft_magnitude magnitude) = 0;
   112     virtual
fft_shift get_shift_config() const = 0;
   124     virtual
void set_scaling(const uint16_t scaling) = 0;
   132     virtual uint16_t get_scaling() const = 0;
   142     virtual
void set_length(const
size_t length) = 0;
   150     virtual
size_t get_length() const = 0;
fft_magnitude
Definition: fft_block_control.hpp:16
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:22
Definition: build_info.hpp:12
Definition: noc_block_base.hpp:42
fft_shift
Definition: fft_block_control.hpp:14
Definition: config.h:87
fft_direction
Definition: fft_block_control.hpp:15
Definition: fft_block_control.hpp:41
UHD_INLINE size_t shift(const soft_reg_field_t field)
Definition: soft_register.hpp:80
