uhd::rfnoc Namespace Reference
Namespaces
 chdr
 detail
 rf_control
Classes
struct  action_info
class  addsub_block_control
class  block_control
class  block_id_t
class  blockdef
class  ddc_block_control
class  dirtifier_t
class  dmafifo_block_control
class  duc_block_control
class  fft_block_control
class  fir_filter_block_control
class  fosphor_block_control
struct  graph_edge_t
class  keep_one_in_n_block_control
class  logpwr_block_control
class  mb_controller
struct  mock_block_container
class  mock_reg_iface_t
class  moving_average_block_control
class  multichan_register_iface
class  noc_block_base
class  node_t
class  null_block_control
class  property_base_t
class  property_t
class  radio_control
class  register_iface
class  register_iface_holder
class  registry
class  replay_block_control
struct  res_source_info
class  rfnoc_graph
struct  rx_event_action_info
class  siggen_block_control
class  split_stream_block_control
struct  stream_cmd_action_info
class  switchboard_block_control
class  traffic_counter
struct  tx_event_action_info
class  vector_iir_block_control
class  window_block_control
Typedefs
using io_type_t = std::string
using noc_id_t = uint32_t
using device_type_t = uint16_t
 Device Type. More...
using sep_id_t = uint16_t
 Stream Endpoint ID Type. More...
using block_port_def = std::tuple< std::string, boost::optional< size_t > >
 Tuple that stores a block ID, as well as an optional port number. More...
Enumerations
enum  fft_shift { fft_shift::NORMAL, fft_shift::REVERSE, fft_shift::NATURAL }
enum  fft_direction { fft_direction::REVERSE, fft_direction::FORWARD }
enum  fft_magnitude { fft_magnitude::COMPLEX, fft_magnitude::MAGNITUDE, fft_magnitude::MAGNITUDE_SQUARED }
enum  fosphor_waterfall_mode { fosphor_waterfall_mode::MAX_HOLD, fosphor_waterfall_mode::AVERAGE }
enum  fosphor_waterfall_predivision_ratio { fosphor_waterfall_predivision_ratio::RATIO_1_1, fosphor_waterfall_predivision_ratio::RATIO_1_8, fosphor_waterfall_predivision_ratio::RATIO_1_64, fosphor_waterfall_predivision_ratio::RATIO_1_256 }
enum  chdr_w_t { CHDR_W_64 = 0, CHDR_W_128 = 1, CHDR_W_256 = 2, CHDR_W_512 = 3 }
 Type that indicates the CHDR Width in bits. More...
enum  siggen_waveform { siggen_waveform::CONSTANT, siggen_waveform::SINE_WAVE, siggen_waveform::NOISE }
Functions
std::ostream & operator<< (std::ostream &out, block_id_t block_id)
 Shortcut for << block_id.to_string() More...
UHD_API mock_block_container get_mock_block (const noc_id_t noc_id, const size_t num_inputs=1, const size_t num_outputs=1, const uhd::device_addr_t &args=uhd::device_addr_t(), const size_t mtu=8000, const device_type_t device_id=ANY_DEVICE, std::shared_ptr< mock_reg_iface_t > client_reg_iface=nullptr, mb_controller::sptr mbc=nullptr)
constexpr size_t chdr_w_to_bits (chdr_w_t chdr_w)
 Conversion from chdr_w_t to a number of bits. More...
constexpr chdr_w_t bits_to_chdr_w (size_t bits)
 Conversion from number of bits to chdr_w_t. More...
std::vector< graph_edge_t > UHD_API get_block_chain (const rfnoc_graph::sptr graph, const block_id_t start_block, const size_t port, const bool source_chain)
std::vector< graph_edge_t > UHD_API connect_through_blocks (rfnoc_graph::sptr graph, const block_id_t src_blk, const size_t src_port, const block_id_t dst_blk, const size_t dst_port, const bool skip_property_propagation=false)
Variables
constexpr uint16_t RFNOC_PROTO_VER = 0x0100
Typedef Documentation
◆ block_port_def
using uhd::rfnoc::block_port_def = typedef std::tuple<std::string, boost::optional<size_t> >
◆ device_type_t
using uhd::rfnoc::device_type_t = typedef uint16_t
Device Type.
◆ io_type_t
using uhd::rfnoc::io_type_t = typedef std::string
◆ noc_id_t
using uhd::rfnoc::noc_id_t = typedef uint32_t
The NoC ID is the unique identifier of the block type. All blocks of the same type have the same NoC ID.
◆ sep_id_t
using uhd::rfnoc::sep_id_t = typedef uint16_t
◆ chdr_w_t
Enumerator
CHDR_W_64
CHDR_W_128
CHDR_W_256
CHDR_W_512
◆ fft_direction
Enumerator
REVERSE
FORWARD
◆ fft_magnitude
Enumerator
COMPLEX
MAGNITUDE
MAGNITUDE_SQUARED
◆ fft_shift
enum uhd::rfnoc::fft_shift
strong
Enumerator
NORMAL
REVERSE
NATURAL
◆ fosphor_waterfall_mode
Enumerator
MAX_HOLD
AVERAGE
◆ fosphor_waterfall_predivision_ratio
Enumerator
RATIO_1_1
RATIO_1_8
RATIO_1_64
RATIO_1_256
◆ siggen_waveform
Enumerator
CONSTANT
SINE_WAVE
NOISE
Function Documentation
◆ bits_to_chdr_w()
constexpr chdr_w_t uhd::rfnoc::bits_to_chdr_w ( size_t  bits)
◆ chdr_w_to_bits()
constexpr size_t uhd::rfnoc::chdr_w_to_bits ( chdr_w_t  chdr_w)
◆ connect_through_blocks()
std::vector<graph_edge_t> UHD_API uhd::rfnoc::connect_through_blocks ( rfnoc_graph::sptr  graph,
const bool  skip_property_propagation = false
Connect desired blocks by whatever path that can be found
This will find the most direct path from a source block to a destination block. If these blocks are statically connected it will simply call connect() on all intermediate connections. If not, it will create a dynamic connection between stream endpoints. If this is not possible, an exception is thrown.
graphThe rfnoc_graph that is being examined
src_blkSource block's ID
src_portBlock port where the path starts
dst_blkDestination block's ID
dst_portBlock port where the path ends
skip_property_propagationDeclare back-edge (see also uhd::rfnoc::rfnoc_graph::connect()) If true, it will declare only the first connection in this chain as a back-edge.
The edge list representing the data path requested
◆ get_block_chain()
std::vector<graph_edge_t> UHD_API uhd::rfnoc::get_block_chain ( const rfnoc_graph::sptr  graph,
const size_t  port,
Get a chain of blocks that statically connect back to a terminating block. This vector's first element is start_block, and the chain continues from there.
This function does not make the connections between blocks, it simply traverses the static connections.
start_blockThe block we begin to build the chain from
portThe block port of src_port that the path will begin at
source_chainWhether or not the start_block is a source (or a destination). If true, the chain will start at start_block's output port. If false, the chain will start with start_block's input port.
◆ get_mock_block()
UHD_API mock_block_container uhd::rfnoc::get_mock_block ( const noc_id_t  noc_id,
const size_t  num_inputs = 1,
const size_t  num_outputs = 1,
const uhd::device_addr_t &  args = uhd::device_addr_t(),
const size_t  mtu = 8000,
const device_type_t  device_id = ANY_DEVICE,
std::shared_ptr< mock_reg_iface_t >  client_reg_iface = nullptr,
mb_controller::sptr  mbc = nullptr
Factory function for mock block controllers
◆ operator<<()
std::ostream& uhd::rfnoc::operator<< ( std::ostream &  out,
block_id_t  block_id
Variable Documentation
◆ RFNOC_PROTO_VER
constexpr uint16_t uhd::rfnoc::RFNOC_PROTO_VER = 0x0100
