uhd::log Namespace Reference
Classes
struct  logging_info
Typedefs
typedef std::function< void(const uhd::log::logging_info &)> log_fn_t
Enumerations
enum  severity_level {
  trace = 0, debug = 1, info = 2, warning = 3,
  error = 4, fatal = 5, off = 6
Functions
boost::optional< uhd::log::severity_level > UHD_API parse_log_level_from_string (const std::string &log_level_str)
UHD_API void set_log_level (uhd::log::severity_level level)
UHD_API void set_console_level (uhd::log::severity_level level)
UHD_API void set_file_level (uhd::log::severity_level level)
UHD_API void set_logger_level (const std::string &logger, uhd::log::severity_level level)
UHD_API void add_logger (const std::string &key, log_fn_t logger_fn)
Typedef Documentation
◆ log_fn_t
typedef std::function<void(const uhd::log::logging_info&)> uhd::log::log_fn_t
Logging function type
Every logging_backend has to define a function with this signature. Can be added to the logging core.
◆ severity_level
Logging severity levels
Either numeric value or string can be used to define loglevel in CMake and environment variables
Enumerator
trace
displays every available log message
debug
displays most log messages necessary for debugging internals
info
informational messages about setup and what is going on
warning
something is not right but operation can continue
error
something has gone wrong
fatal
something has gone horribly wrong
off
logging is turned off
Function Documentation
◆ add_logger()
UHD_API void uhd::log::add_logger ( const std::string &  key,
log_fn_t  logger_fn
Add logging backend to the log system
keyIdentifies the logging backend in the logging core
logger_fnfunction which actually logs messages to this backend
◆ parse_log_level_from_string()
boost::optional<uhd::log::severity_level> UHD_API uhd::log::parse_log_level_from_string ( const std::string &  log_level_str)
Parses a severity_level from a string. If a value could not be parsed, returns none.
◆ set_console_level()
UHD_API void uhd::log::set_console_level ( uhd::log::severity_level  level)
Set the log level for the console logger (if defined).
Short-hand for set_logger_level("console", level);
◆ set_file_level()
UHD_API void uhd::log::set_file_level ( uhd::log::severity_level  level)
Set the log level for the file logger (if defined)
Short-hand for set_logger_level("file", level);
◆ set_log_level()
UHD_API void uhd::log::set_log_level ( uhd::log::severity_level  level)
Set the global log level
The global log level gets applied before the specific log level. So, if the global log level is 'info', no logger can can print messages at level 'debug' or below.
◆ set_logger_level()
UHD_API void uhd::log::set_logger_level ( const std::string &  logger,
Set the log level for any specific logger.
loggerName of the logger
levelNew log level for this logger.
Exceptions
uhd::key_errorif logger was not defined
