Like other USRP devices (e.g., E310, X310), the X4x0 devices expose auxiliary GPIO connections through the motherboard. These GPIO pins can be controlled from either the user application in the FPGA or from the radio blocks.
There are 24 GPIO pins in total, split between two HDMI connectors (labelled GPIO0 and GPIO1) which each expose 12 pins.
Additionally, the X4x0 GPIO lines include a 3.3V power supply which is disabled by default, which can provide up to 450mA with overcurrent protection. See Configuring External Power Supply
The GPIO port is not meant to drive big loads.
The GPIO lines can be configured according to the uhd::usrp::multi_usrp::set_gpio_attr() API, like can be seen at Explaining ATR.
The major difference is that in order to use that API, the GPIO source must be correctly configured. The source can be configured using uhd::usrp::multi_usrp::set_gpio_src(), which takes two arguments: A "bank" and a "src". The bank argument specifies the GPIO port to configure, and the src argument is a vector of twelve elements, each specifying the source for the given GPIO pin.
The bank can be either "GPIO0" or "GPIO1", and the sources can be any combination of:
Once the source is set, using the GPIO proceeds identically to the usage on other devices. Note that the values and masks for the uhd::usrp::multi_usrp::set_gpio_attr() API combines all 24 pins, with bits [23:12] representing the GPIO1 port and bits [11:0] representing the GPIO0 port. For example, to configure the 4th bit on GPIO1 (HDMI pin number 7) as a high output, one would run:
The X410's GPIO ports each have 3.3V power supply pins, which is disabled by default. The GPIO lines will function correctly without the external power supply enabled, and the voltage of the power supply is independent of the selected GPIO line voltage. To enable the power supply, call the uhd::features::gpio_power_iface::set_external_power() method on the gpio_power discoverable feature attached to the mb_controller:
The status of the external power supply can be queried using uhd::features::gpio_power_iface::get_external_power_status(), which will return one of the following values:
The voltage level of the I/O lines can be selected as any of 1.8V, 2.5V, or 3.3V voltage levels on a per-bank basis. To do this use the uhd::features::gpio_power_iface::set_port_voltage() API:
Valid values can be enumerated with the uhd::features::gpio_power_iface::supported_voltages() call, and are "1V8", "2V5", and "3V3".
The GPIO ports of the x4x0 can be used with the Serial Peripheral Interface (SPI) to control external components. To use SPI mode, set the pins you need on the desired GPIO port to be controlled by the SPI engine and configure the data direction.
The example shows the usage of GPIO port 0 (GPIO0) for SPI and needs to be run for GPIO1 again to use that port with SPI, too.
The x4x0 SPI mode supports up to 4 peripherals. All of these peripherals may have a different SPI pin configuration. The pins available for the usage with SPI are listed in Pin Mapping. For GPIO0 the available pins are enumerated from 0 through 11, for GPIO1 the available pins are from 12 through 23. The vector of peripheral configurations is passed to the spi_iface_getter to get the reference:
With the SPI reference read and write operations can be performed. For doing this, some characteristics of the SPI need to be configured:
The terms 'MISO' and 'MOSI' in the spi_config_t struct map to 'SDI' and 'SDO' respectively. They are legacy terms which will not be used in new code anymore following the resolution to redefine SPI signal names by the Open Source Hardware Association: https://www.oshwa.org/a-resolution-to-redefine-spi-signal-names/
The SPI clock SCLK is derived from the Radio clock and the SPI clock divider as follows:
SCLK = \frac{Radio\_Clk}{SPI\_CLK\_DIV + 1}
