18 #define UHD_RFNOC_BLOCK_REGISTER_FOR_DEVICE_DIRECT(                             \    19     CLASS_NAME, NOC_ID, DEVICE_ID, BLOCK_NAME, MB_ACCESS, TB_CLOCK, CTRL_CLOCK) \    20     uhd::rfnoc::noc_block_base::sptr CLASS_NAME##_make(                         \    21         uhd::rfnoc::noc_block_base::make_args_ptr make_args)                    \    23         return std::make_shared<CLASS_NAME##_impl>(std::move(make_args));       \    25     UHD_STATIC_BLOCK(register_rfnoc_##CLASS_NAME)                               \    27         uhd::rfnoc::registry::register_block_direct(NOC_ID,                     \    33             &CLASS_NAME##_make);                                                \    36 #define UHD_RFNOC_BLOCK_REGISTER_DIRECT(                  \    37     CLASS_NAME, NOC_ID, BLOCK_NAME, TB_CLOCK, CTRL_CLOCK) \    38     UHD_RFNOC_BLOCK_REGISTER_FOR_DEVICE_DIRECT(           \    39         CLASS_NAME, NOC_ID, ANY_DEVICE, BLOCK_NAME, false, TB_CLOCK, CTRL_CLOCK)    41 #define UHD_RFNOC_BLOCK_REGISTER_DIRECT_MB_ACCESS(        \    42     CLASS_NAME, NOC_ID, BLOCK_NAME, TB_CLOCK, CTRL_CLOCK) \    43     UHD_RFNOC_BLOCK_REGISTER_FOR_DEVICE_DIRECT(           \    44         CLASS_NAME, NOC_ID, ANY_DEVICE, BLOCK_NAME, true, TB_CLOCK, CTRL_CLOCK)    46 namespace uhd {
namespace rfnoc {
    55     using factory_t = std::function<noc_block_base::sptr(noc_block_base::make_args_ptr)>;
    87     static void register_block_direct(
noc_id_t noc_id,
    89         const std::string& block_name,
    91         const std::string& timebase_clock,
    92         const std::string& ctrlport_clock,
   106     static void register_block_descriptor(
   107         const std::string& block_key,
factory_t factory_fn);
Definition: registry.hpp:52
Definition: build_info.hpp:12
uint16_t device_type_t
Device Type.
Definition: defaults.hpp:54
Definition: config.h:87
std::function< noc_block_base::sptr(noc_block_base::make_args_ptr)> factory_t
Definition: registry.hpp:55
uint32_t noc_id_t
Definition: defaults.hpp:50
