12 namespace uhd {
namespace rfnoc {
   116     static const uint16_t MINOR_COMPAT;
   117     static const uint16_t MAJOR_COMPAT;
   119     static const uint32_t REPLAY_ADDR_W;
   120     static const uint32_t REPLAY_BLOCK_OFFSET;
   122     static const uint32_t REG_COMPAT_ADDR;
   123     static const uint32_t REG_MEM_SIZE_ADDR;
   124     static const uint32_t REG_REC_RESTART_ADDR;
   125     static const uint32_t REG_REC_BASE_ADDR_LO_ADDR;
   126     static const uint32_t REG_REC_BASE_ADDR_HI_ADDR;
   127     static const uint32_t REG_REC_BUFFER_SIZE_LO_ADDR;
   128     static const uint32_t REG_REC_BUFFER_SIZE_HI_ADDR;
   129     static const uint32_t REG_REC_FULLNESS_LO_ADDR;
   130     static const uint32_t REG_REC_FULLNESS_HI_ADDR;
   131     static const uint32_t REG_PLAY_BASE_ADDR_LO_ADDR;
   132     static const uint32_t REG_PLAY_BASE_ADDR_HI_ADDR;
   133     static const uint32_t REG_PLAY_BUFFER_SIZE_LO_ADDR;
   134     static const uint32_t REG_PLAY_BUFFER_SIZE_HI_ADDR;
   135     static const uint32_t REG_PLAY_CMD_NUM_WORDS_LO_ADDR;
   136     static const uint32_t REG_PLAY_CMD_NUM_WORDS_HI_ADDR;
   137     static const uint32_t REG_PLAY_CMD_TIME_LO_ADDR;
   138     static const uint32_t REG_PLAY_CMD_TIME_HI_ADDR;
   139     static const uint32_t REG_PLAY_CMD_ADDR;
   140     static const uint32_t REG_PLAY_WORDS_PER_PKT_ADDR;
   141     static const uint32_t REG_PLAY_ITEM_SIZE_ADDR;
   142     static const uint32_t REG_REC_POS_LO_ADDR;
   143     static const uint32_t REG_REC_POS_HI_ADDR;
   144     static const uint32_t REG_PLAY_POS_LO_ADDR;
   145     static const uint32_t REG_PLAY_POS_HI_ADDR;
   146     static const uint32_t REG_PLAY_CMD_FIFO_SPACE_ADDR;
   148     static const uint32_t PLAY_CMD_STOP;
   149     static const uint32_t PLAY_CMD_FINITE;
   150     static const uint32_t PLAY_CMD_CONTINUOUS;
   172         const uint64_t offset, const uint64_t size, const
size_t port = 0) = 0;
   180     virtual
void record_restart(const
   222     virtual
void play(const uint64_t offset,
   224         const
size_t port                = 0,
   226         const
bool repeat                = false) = 0;
   235     virtual
void stop(const
   244     virtual uint64_t get_mem_size() const = 0;
   250     virtual uint64_t get_word_size() const = 0;
   260     virtual uint64_t get_record_offset(const
size_t port = 0) const = 0;
   267     virtual uint64_t get_record_size(const
   277     virtual uint64_t get_record_fullness(const
   284     virtual uint64_t get_record_position(const
   291     virtual
io_type_t get_record_type(const
   298     virtual
size_t get_record_item_size(const
   313     virtual
bool get_record_async_metadata(
   324     virtual uint64_t get_play_offset(const
   331     virtual uint64_t get_play_size(const
   338     virtual uint64_t get_play_position(const
   345     virtual uint32_t get_max_items_per_packet(const
   354     virtual uint32_t get_max_packet_size(const
   361     virtual
io_type_t get_play_type(const
   368     virtual
size_t get_play_item_size(const
   383     virtual
bool get_play_async_metadata(
   396     virtual
void set_record_type(const
io_type_t type, const
   415     virtual
void config_play(
   416         const uint64_t offset, const uint64_t size, const
   425     virtual
void set_play_type(const
   436     virtual
void set_max_items_per_packet(const uint32_t ipp, const
   446     virtual
void set_max_packet_size(const uint32_t size, const
   464     virtual
void issue_stream_cmd(
 Definition: stream_cmd.hpp:39
Definition: time_spec.hpp:28
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:22
Definition: build_info.hpp:12
Definition: noc_block_base.hpp:42
Definition: config.h:87
Definition: replay_block_control.hpp:111
std::string io_type_t
Definition: defaults.hpp:31
