vrt_if_packet.hpp
2 // Copyright 2010-2014 Ettus Research LLC
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.hpp>
11 #include <stdint.h>
12 #include <cstddef> //size_t
13
14 namespace uhd { namespace transport { namespace vrt {
15
17 static const size_t num_vrl_words32 = 3;
18
20 static const size_t max_if_hdr_words32 = 7; // hdr+sid+cid+tsi+tsf
21
28 {
29  if_packet_info_t(void);
30
31  // link layer type - always set for pack and unpack
32  enum link_type_t {
33  LINK_TYPE_NONE = 0x0,
34  LINK_TYPE_CHDR = 0x1,
35  LINK_TYPE_VRLP = 0x2
36  } link_type;
37
38  // packet type
40  // VRT language:
41  PACKET_TYPE_DATA = 0x0,
42  PACKET_TYPE_IF_EXT = 0x1,
43  PACKET_TYPE_CONTEXT = 0x2, // extension context: has_sid = true
44
45  // CHDR language:
46  // PACKET_TYPE_DATA = 0x0, // Data
47  PACKET_TYPE_FC = 0x1, // Flow control
48  PACKET_TYPE_ACK = 0x1, // Flow control (ack)
49  PACKET_TYPE_CMD = 0x2, // Command
50  PACKET_TYPE_RESP = 0x3, // Command response
51  PACKET_TYPE_ERROR =
52  0x3 // Command response: Error (the EOB bit is raised in this case)
53  } packet_type;
54
55  // size fields
56  size_t num_payload_words32; // required in pack, derived in unpack
57  size_t num_payload_bytes; // required in pack, derived in unpack
58  size_t num_header_words32; // derived in pack, derived in unpack
59  size_t num_packet_words32; // derived in pack, required in unpack
60
61  // header fields
62  size_t packet_count;
64  bool sob, eob;
66  bool error;
68  bool fc_ack;
69
70  // optional fields
72  bool has_sid;
73  uint32_t sid;
75  bool has_cid;
76  uint64_t cid;
78  bool has_tsi;
79  uint32_t tsi;
81  bool has_tsf;
82  uint64_t tsf;
84  bool has_tlr;
85  uint32_t tlr;
86 };
87
113 UHD_API void if_hdr_pack_be(uint32_t* packet_buff, if_packet_info_t& if_packet_info);
114
149  const uint32_t* packet_buff, if_packet_info_t& if_packet_info);
150
159 UHD_API void if_hdr_pack_le(uint32_t* packet_buff, if_packet_info_t& if_packet_info);
160
170  const uint32_t* packet_buff, if_packet_info_t& if_packet_info);
171
173  : link_type(LINK_TYPE_NONE)
174  , packet_type(PACKET_TYPE_DATA)
175  , num_payload_words32(0)
176  , num_payload_bytes(0)
177  , num_header_words32(0)
178  , num_packet_words32(0)
179  , packet_count(0)
180  , sob(false)
181  , eob(false)
182  , error(false)
183  , fc_ack(false)
184  , has_sid(false)
185  , sid(0)
186  , has_cid(false)
187  , cid(0)
188  , has_tsi(false)
189  , tsi(0)
190  , has_tsf(false)
191  , tsf(0)
192  , has_tlr(false)
193  , tlr(0)
194 {
195 }
196
197 }}} // namespace uhd::transport::vrt
uint64_t cid
Definition: vrt_if_packet.hpp:76
Definition: vrt_if_packet.hpp:27
Definition: vrt_if_packet.hpp:59
UHD_API void if_hdr_unpack_le(const uint32_t *packet_buff, if_packet_info_t &if_packet_info)
Definition: vrt_if_packet.hpp:172
packet_type_t
Definition: vrt_if_packet.hpp:39
uint64_t tsf
Definition: vrt_if_packet.hpp:82
UHD_API void if_hdr_unpack_be(const uint32_t *packet_buff, if_packet_info_t &if_packet_info)
bool has_cid
Class ID.
Definition: vrt_if_packet.hpp:75
link_type_t
Definition: vrt_if_packet.hpp:32
uint32_t tlr
Definition: vrt_if_packet.hpp:85
Definition: build_info.hpp:12
uint32_t sid
Definition: vrt_if_packet.hpp:73
UHD_API void if_hdr_pack_be(uint32_t *packet_buff, if_packet_info_t &if_packet_info)
bool error
This is asserted for command responses that are errors (CHDR only)
Definition: vrt_if_packet.hpp:66
Definition: vrt_if_packet.hpp:57
bool has_tsi
Integer timestamp.
Definition: vrt_if_packet.hpp:78
#define UHD_INLINE
Definition: config.h:65
bool has_tsf
Fractional timestamp.
Definition: vrt_if_packet.hpp:81
Definition: log.hpp:121
size_t packet_count
Definition: vrt_if_packet.hpp:62
Definition: config.h:87
bool has_sid
Stream ID (SID).
Definition: vrt_if_packet.hpp:72
Definition: vrt_if_packet.hpp:56
bool fc_ack
This is asserted for flow control packets are ACKS (CHDR only)
Definition: vrt_if_packet.hpp:68
UHD_API void if_hdr_pack_le(uint32_t *packet_buff, if_packet_info_t &if_packet_info)
bool has_tlr
Trailer.
Definition: vrt_if_packet.hpp:84
Definition: vrt_if_packet.hpp:58
bool sob
Asserted for start- or end-of-burst.
Definition: vrt_if_packet.hpp:64
uint32_t tsi
Definition: vrt_if_packet.hpp:79
