uhd::digital_filter_fir< tap_t > Class Template Reference
Inheritance diagram for uhd::digital_filter_fir< tap_t >:
uhd::digital_filter_base< tap_t > uhd::filter_info_base
typedef std::shared_ptr< digital_filter_fir< tap_t > > sptr
- Public Types inherited from uhd::digital_filter_base< tap_t >
typedef std::shared_ptr< digital_filter_basesptr
- Public Types inherited from uhd::filter_info_base
enum  filter_type { ANALOG_LOW_PASS, ANALOG_BAND_PASS, DIGITAL_I16, DIGITAL_FIR_I16 }
typedef std::shared_ptr< filter_info_basesptr
 digital_filter_fir (filter_info_base::filter_type type, bool bypass, size_t position_index, double rate, uint32_t interpolation, uint32_t decimation, tap_t tap_bit_width, uint32_t max_num_taps, const std::vector< tap_t > &taps)
void set_taps (const std::vector< tap_t > &taps)
- Public Member Functions inherited from uhd::digital_filter_base< tap_t >
 digital_filter_base (filter_type type, bool bypass, size_t position_index, double rate, uint32_t interpolation, uint32_t decimation, tap_t tap_full_scale, uint32_t max_num_taps, const std::vector< tap_t > &taps)
UHD_INLINE double get_output_rate ()
UHD_INLINE double get_input_rate ()
UHD_INLINE uint32_t get_interpolation ()
UHD_INLINE uint32_t get_decimation ()
UHD_INLINE uint32_t get_tap_full_scale ()
UHD_INLINE std::vector< tap_t > & get_taps ()
std::string to_pp_string () override
- Public Member Functions inherited from uhd::filter_info_base
 filter_info_base (filter_type type, bool bypass, size_t position_index)
virtual UHD_INLINE bool is_bypassed ()
UHD_INLINE filter_type get_type ()
virtual ~filter_info_base ()
- Protected Attributes inherited from uhd::digital_filter_base< tap_t >
double _rate
uint32_t _interpolation
uint32_t _decimation
tap_t _tap_full_scale
uint32_t _max_num_taps
std::vector< tap_t > _taps
- Protected Attributes inherited from uhd::filter_info_base
filter_type _type
bool _bypass
size_t _position_index
template<typename tap_t >
typedef std::shared_ptr<digital_filter_fir<tap_t> > uhd::digital_filter_fir< tap_t >::sptr
◆ digital_filter_fir()
uhd::digital_filter_fir< tap_t >::digital_filter_fir ( filter_info_base::filter_type  type,
bool  bypass,
double  rate,
const std::vector< tap_t > &  taps
◆ set_taps()
void uhd::digital_filter_fir< tap_t >::set_taps ( const std::vector< tap_t > &  taps)
