uhd::rfnoc::chdr::ctrl_payload Class Reference
 ctrl_payload ()=default
 ctrl_payload (const ctrl_payload &rhs)=default
 ctrl_payload (ctrl_payload &&rhs)=default
ctrl_payload & operator= (const ctrl_payload &rhs)=default
void populate_header (chdr_header &header) const
 Populate the header for this type of packet. More...
size_t serialize (uint64_t *buff, size_t max_size_bytes, const std::function< uint64_t(uint64_t)> &conv_byte_order) const
 Serialize the payload to a uint64_t buffer. More...
size_t serialize (uint64_t *buff, size_t max_size_bytes) const
 Serialize the payload to a uint64_t buffer (no conversion function) More...
void deserialize (const uint64_t *buff, size_t buff_size, const std::function< uint64_t(uint64_t)> &conv_byte_order)
void deserialize (const uint64_t *buff, size_t buff_size)
size_t get_length () const
 Get the serialized size of this payload in 64 bit words. More...
bool has_timestamp () const
bool operator== (const ctrl_payload &rhs) const
 Comparison operator (==) More...
bool operator!= (const ctrl_payload &rhs) const
 Comparison operator (!=) More...
const std::string to_string () const
 Return a string representation of this object. More...
Public Attributes
uint16_t dst_port = 0
 Destination port for transaction (10 bits) More...
uint16_t src_port = 0
 Source port for transaction (10 bits) More...
uint8_t seq_num = 0
 Sequence number (6 bits) More...
boost::optional< uint64_t > timestamp = boost::none
 Has Time Flag (1 bit) and timestamp (64 bits) More...
bool is_ack = false
 Is Acknowledgment Flag (1 bit) More...
uint16_t src_epid = 0
 Source endpoint ID of transaction (16 bits) More...
uint32_t address = 0
 Address for transaction (20 bits) More...
std::vector< uint32_t > data_vtr = {0}
 Data for transaction (vector of 32 bits) More...
uint8_t byte_enable = 0xF
 Byte-enable mask for transaction (4 bits) More...
ctrl_opcode_t op_code = OP_SLEEP
 Operation code (4 bits) More...
ctrl_status_t status = CMD_OKAY
 Transaction status (4 bits) More...
◆ ctrl_payload() [1/3]
uhd::rfnoc::chdr::ctrl_payload::ctrl_payload ( )
default
◆ ctrl_payload() [2/3]
uhd::rfnoc::chdr::ctrl_payload::ctrl_payload ( const ctrl_payload &  rhs)
default
◆ ctrl_payload() [3/3]
uhd::rfnoc::chdr::ctrl_payload::ctrl_payload ( ctrl_payload &&  rhs)
default
◆ deserialize() [1/2]
void uhd::rfnoc::chdr::ctrl_payload::deserialize ( const uint64_t *  buff,
size_t  buff_size,
const std::function< uint64_t(uint64_t)> &  conv_byte_order
Deserialize the payload from a uint64_t buffer
buffBuffer to deserialize the payload from
buff_sizeNumber of elements in the buffer
conv_byte_orderByte order converter function (buffer to host endianness)
◆ deserialize() [2/2]
size_t  buff_size
Deserialize the payload from a uint64_t buffer (no conversion function)
◆ get_length()
size_t uhd::rfnoc::chdr::ctrl_payload::get_length ( ) const
◆ has_timestamp()
bool uhd::rfnoc::chdr::ctrl_payload::has_timestamp ( ) const
◆ operator!=()
bool uhd::rfnoc::chdr::ctrl_payload::operator!= ( const ctrl_payload &  rhs) const
◆ operator=()
ctrl_payload& uhd::rfnoc::chdr::ctrl_payload::operator= ( const ctrl_payload &  rhs)
default
◆ operator==()
bool uhd::rfnoc::chdr::ctrl_payload::operator== ( const ctrl_payload &  rhs) const
◆ populate_header()
void uhd::rfnoc::chdr::ctrl_payload::populate_header ( chdr_header &  header) const
◆ serialize() [1/2]
size_t uhd::rfnoc::chdr::ctrl_payload::serialize ( uint64_t *  buff,
) const
◆ serialize() [2/2]
) const
◆ to_string()
const std::string uhd::rfnoc::chdr::ctrl_payload::to_string ( ) const
◆ address
uint32_t uhd::rfnoc::chdr::ctrl_payload::address = 0
◆ byte_enable
uint8_t uhd::rfnoc::chdr::ctrl_payload::byte_enable = 0xF
◆ data_vtr
std::vector<uint32_t> uhd::rfnoc::chdr::ctrl_payload::data_vtr = {0}
◆ dst_port
uint16_t uhd::rfnoc::chdr::ctrl_payload::dst_port = 0
◆ is_ack
bool uhd::rfnoc::chdr::ctrl_payload::is_ack = false
◆ op_code
ctrl_opcode_t uhd::rfnoc::chdr::ctrl_payload::op_code = OP_SLEEP
◆ seq_num
uint8_t uhd::rfnoc::chdr::ctrl_payload::seq_num = 0
◆ src_epid
uint16_t uhd::rfnoc::chdr::ctrl_payload::src_epid = 0
◆ src_port
uint16_t uhd::rfnoc::chdr::ctrl_payload::src_port = 0
◆ status
ctrl_status_t uhd::rfnoc::chdr::ctrl_payload::status = CMD_OKAY
◆ timestamp
boost::optional<uint64_t> uhd::rfnoc::chdr::ctrl_payload::timestamp = boost::none
