22 namespace uhd {
namespace usrp {
    55     typedef std::shared_ptr<dboard_iface>
sptr;
    74     enum aux_adc_t { AUX_ADC_A = int(
'a'), AUX_ADC_B = int(
'b') };
    86     virtual special_props_t get_special_props(
void) = 0;
    95     virtual void write_aux_dac(
unit_t unit,
aux_dac_t which_dac,
double value) = 0;
   113     virtual void set_pin_ctrl(
unit_t unit, uint32_t value, uint32_t
mask = 0xffff) = 0;
   121     virtual uint32_t get_pin_ctrl(
unit_t unit) = 0;
   131     virtual void set_atr_reg(
   132         unit_t unit, atr_reg_t reg, uint32_t value, uint32_t
mask = 0xffff) = 0;
   141     virtual uint32_t get_atr_reg(
unit_t unit, atr_reg_t reg) = 0;
   150     virtual void set_gpio_ddr(
mask = 0xffff) = 0;
   158     virtual uint32_t get_gpio_ddr(
unit_t unit) = 0;
   167     virtual void set_gpio_out(
mask = 0xffff) = 0;
   175     virtual uint32_t get_gpio_out(
unit_t unit) = 0;
   183     virtual uint32_t read_gpio(
unit_t unit) = 0;
   193     virtual void write_spi(
   205     virtual uint32_t read_write_spi(
   214     virtual void set_clock_rate(
unit_t unit,
double rate) = 0;
   222     virtual double get_clock_rate(
unit_t unit) = 0;
   230     virtual std::vector<double> get_clock_rates(
unit_t unit) = 0;
   238     virtual void set_clock_enabled(
unit_t unit,
bool enb) = 0;
   247     virtual double get_codec_rate(
unit_t unit) = 0;
   256     virtual void set_fe_connection(
unit_t unit,
   257         const std::string& fe_name,
   283     virtual void sleep(
const std::chrono::nanoseconds& time);
aux_adc_t
Definition: dboard_iface.hpp:74
Definition: serial.hpp:35
~dboard_iface(void) override
Definition: dboard_iface.hpp:78
uhd::usrp::gpio_atr::gpio_atr_reg_t atr_reg_t
Definition: dboard_iface.hpp:76
Definition: time_spec.hpp:28
aux_dac_t
Definition: dboard_iface.hpp:66
Definition: build_info.hpp:12
Definition: dboard_iface.hpp:52
bool soft_clock_divider
Definition: dboard_iface.hpp:33
Definition: serial.hpp:82
Definition: fe_connection.hpp:16
gpio_atr_reg_t
Definition: gpio_defs.hpp:12
std::shared_ptr< dboard_iface > sptr
Definition: dboard_iface.hpp:55
Definition: config.h:87
Definition: soft_register.hpp:86
Definition: dboard_iface.hpp:56
Definition: dboard_iface.hpp:25
virtual bool has_set_fe_connection(const unit_t)
Definition: dboard_iface.hpp:262
unit_t
Definition: dboard_iface.hpp:59
bool mangle_i2c_addrs
Definition: dboard_iface.hpp:43
