Loading [MathJax]/jax/output/HTML-CSS/config.js
uhd::spi_config_t Struct Reference
enum  edge_t { EDGE_RISE = 'r', EDGE_FALL = 'f' }
 spi_config_t (edge_t edge=EDGE_RISE)
 spi_config_t (edge_t edge, size_t divider)
Public Attributes
edge_t mosi_edge
 on what edge is the mosi data valid? More...
edge_t miso_edge
 on what edge is the miso data valid? More...
bool use_custom_divider
 Set the clock speed for this transaction. More...
size_t divider
 Optionally set the SPI clock divider for this transaction. More...
The SPI configuration struct: Used to configure a SPI transaction interface.
◆ edge_t
The edge type specifies when data is valid relative to the edge of the serial clock.
Enumerator
EDGE_RISE
EDGE_FALL
◆ spi_config_t() [1/2]
uhd::spi_config_t::spi_config_t ( edge_t  edge = EDGE_RISE)
Create a new spi config.
edgethe default edge for mosi and miso
◆ spi_config_t() [2/2]
uhd::spi_config_t::spi_config_t ( edge_t  edge,
size_t  divider
Create a new spi config with custom divider.
dividerthe divider setting to use
◆ divider
size_t uhd::spi_config_t::divider
◆ miso_edge
edge_t uhd::spi_config_t::miso_edge
◆ mosi_edge
edge_t uhd::spi_config_t::mosi_edge
◆ use_custom_divider
bool uhd::spi_config_t::use_custom_divider
