#include <stdlib.h>
Enumerations | |
enum | uhd_error { UHD_ERROR_NONE = 0, UHD_ERROR_INVALID_DEVICE = 1, UHD_ERROR_INDEX = 10, UHD_ERROR_KEY = 11, UHD_ERROR_NOT_IMPLEMENTED = 20, UHD_ERROR_USB = 21, UHD_ERROR_IO = 30, UHD_ERROR_OS = 31, UHD_ERROR_ASSERTION = 40, UHD_ERROR_LOOKUP = 41, UHD_ERROR_TYPE = 42, UHD_ERROR_VALUE = 43, UHD_ERROR_RUNTIME = 44, UHD_ERROR_ENVIRONMENT = 45, UHD_ERROR_SYSTEM = 46, UHD_ERROR_EXCEPT = 47, UHD_ERROR_BOOSTEXCEPT = 60, UHD_ERROR_STDEXCEPT = 70, UHD_ERROR_UNKNOWN = 100 } |
UHD error codes. More... | |
Functions | |
UHD_API uhd_error | uhd_get_last_error (char *error_out, size_t strbuffer_len) |
Return the last error string reported by UHD. More... | |
enum uhd_error |
UHD error codes.
Each error code corresponds to a specific uhd::exception, with extra codes corresponding to a boost::exception, std::exception, and a catch-all for everything else. When an internal C++ function throws an exception, UHD converts it to one of these error codes to return on the C level.
Enumerator | |
UHD_ERROR_NONE | No error thrown. |
UHD_ERROR_INVALID_DEVICE | Invalid device arguments. |
UHD_ERROR_INDEX | See uhd::index_error. |
UHD_ERROR_KEY | See uhd::key_error. |
UHD_ERROR_NOT_IMPLEMENTED | |
UHD_ERROR_USB | See uhd::usb_error. |
UHD_ERROR_IO | See uhd::io_error. |
UHD_ERROR_OS | See uhd::os_error. |
UHD_ERROR_ASSERTION | See uhd::assertion_error. |
UHD_ERROR_LOOKUP | See uhd::lookup_error. |
UHD_ERROR_TYPE | See uhd::type_error. |
UHD_ERROR_VALUE | See uhd::value_error. |
UHD_ERROR_RUNTIME | See uhd::runtime_error. |
UHD_ERROR_ENVIRONMENT | |
UHD_ERROR_SYSTEM | See uhd::system_error. |
UHD_ERROR_EXCEPT | See uhd::exception. |
UHD_ERROR_BOOSTEXCEPT | A boost::exception was thrown. |
UHD_ERROR_STDEXCEPT | A std::exception was thrown. |
UHD_ERROR_UNKNOWN | An unknown error was thrown. |
Functions that do not take in UHD structs/handles will place any error strings into a buffer that can be queried with this function. Functions that do take in UHD structs/handles will place their error strings in both locations.
