18 namespace uhd {
namespace experts {
    56     template <
typename data_t>
    58         const std::string& name,
    59         const data_t& init_val,
    91     template <
typename data_t>
    95         const std::string& name,
    96         const data_t& init_val,
   107         container->add_data_node(node_ptr, mode);
   123     template <
typename data_t>
   127         const data_t& init_val,
   130         return add_prop_node(container, subtree, path, path, init_val, mode);
   151     template <
typename data_t>
   155         const std::string& desired_name,
   156         const std::string& coerced_name,
   157         const data_t& init_val,
   160         bool auto_resolve_desired =
   162         bool auto_resolve_coerced =
   177         container->add_data_node(desired_node_ptr,
   179         container->add_data_node(coerced_node_ptr,
   197     template <
typename data_t>
   201         const data_t& init_val,
   204         return add_dual_prop_node(container,
   222     template <
typename worker_t>
   225         container->add_worker(
new worker_t());
   242     template <
typename worker_t,
typename arg1_t>
   246         container->add_worker(
new worker_t(arg1));
   249     template <
typename worker_t,
typename arg1_t,
typename arg2_t>
   253         container->add_worker(
new worker_t(arg1, arg2));
   256     template <
typename worker_t,
typename arg1_t,
typename arg2_t,
typename arg3_t>
   262         container->add_worker(
new worker_t(arg1, arg2, arg3));
   265     template <
typename worker_t,
   276         container->add_worker(
new worker_t(arg1, arg2, arg3, arg4));
   279     template <
typename worker_t,
   292         container->add_worker(
new worker_t(arg1, arg2, arg3, arg4, arg5));
   295     template <
typename worker_t,
   310         container->add_worker(
new worker_t(arg1, arg2, arg3, arg4, arg5, arg6));
   313     template <
typename worker_t,
   330         container->add_worker(
new worker_t(arg1, arg2, arg3, arg4, arg5, arg6, arg7));
   333     template <
typename worker_t,
   352         container->add_worker(
   353             new worker_t(arg1, arg2, arg3, arg4, arg5, arg6, arg7, arg8));
 static property< data_t > & add_prop_node(expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const std::string &name, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:92
std::shared_ptr< expert_container > sptr
Definition: expert_container.hpp:28
Definition: property_tree.hpp:205
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3)
Definition: expert_factory.hpp:257
auto_resolve_mode_t
Definition: expert_container.hpp:18
Definition: property_tree.hpp:225
static property< data_t > & add_dual_prop_node(expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:198
static void add_worker_node(expert_container::sptr container)
Definition: expert_factory.hpp:223
Definition: expert_container.hpp:21
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3, arg4_t const &arg4)
Definition: expert_factory.hpp:270
Definition: expert_factory.hpp:31
Definition: expert_container.hpp:19
virtual property< T > & add_coerced_subscriber(const subscriber_type &subscriber)=0
Definition: build_info.hpp:12
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3, arg4_t const &arg4, arg5_t const &arg5)
Definition: expert_factory.hpp:285
virtual property< T > & set_publisher(const publisher_type &publisher)=0
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2)
Definition: expert_factory.hpp:250
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3, arg4_t const &arg4, arg5_t const &arg5, arg6_t const &arg6, arg7_t const &arg7)
Definition: expert_factory.hpp:321
virtual property< T > & set(const T &value)=0
static void add_data_node(expert_container::sptr container, const std::string &name, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:57
Definition: expert_nodes.hpp:128
virtual property< T > & set_coerced(const T &value)=0
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1)
Definition: expert_factory.hpp:243
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3, arg4_t const &arg4, arg5_t const &arg5, arg6_t const &arg6, arg7_t const &arg7, arg7_t const &arg8)
Definition: expert_factory.hpp:342
Definition: expert_container.hpp:20
Definition: config.h:87
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3, arg4_t const &arg4, arg5_t const &arg5, arg6_t const &arg6)
Definition: expert_factory.hpp:302
Definition: expert_container.hpp:22
virtual property< T > & add_desired_subscriber(const subscriber_type &subscriber)=0
Definition: property_tree.hpp:78
Definition: property_tree.hpp:223
static property< data_t > & add_prop_node(expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:124
static property< data_t > & add_dual_prop_node(expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const std::string &desired_name, const std::string &coerced_name, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:152
