fft_block_control.hpp
2 // Copyright 2019 Ettus Research, a National Instruments Brand
5 //
6
7 #pragma once
8
9 #include <uhd/config.hpp>
11
12 namespace uhd { namespace rfnoc {
13
14 enum class fft_shift { NORMAL, REVERSE, NATURAL };
15 enum class fft_direction { REVERSE, FORWARD };
18 // Custom property keys
19 static const std::string PROP_KEY_MAGNITUDE = "magnitude";
20 static const std::string PROP_KEY_DIRECTION = "direction";
21 static const std::string PROP_KEY_LENGTH = "length";
22 static const std::string PROP_KEY_FFT_SCALING = "fft_scaling";
23 static const std::string PROP_KEY_SHIFT_CONFIG = "shift_config";
42 {
43 public:
45
46  static const uint32_t REG_RESET_ADDR;
47  static const uint32_t REG_LENGTH_LOG2_ADDR;
48  static const uint32_t REG_MAGNITUDE_OUT_ADDR;
49  static const uint32_t REG_DIRECTION_ADDR;
50  static const uint32_t REG_SCALING_ADDR;
51  static const uint32_t REG_SHIFT_CONFIG_ADDR;
52
60  virtual void set_direction(const fft_direction direction) = 0;
61
68  virtual fft_direction get_direction() const = 0;
69
81  virtual void set_magnitude(const fft_magnitude magnitude) = 0;
82
89  virtual fft_magnitude get_magnitude() const = 0;
90
104  virtual void set_shift_config(const fft_shift shift) = 0;
105
112  virtual fft_shift get_shift_config() const = 0;
113
124  virtual void set_scaling(const uint16_t scaling) = 0;
125
132  virtual uint16_t get_scaling() const = 0;
133
142  virtual void set_length(const size_t length) = 0;
143
150  virtual size_t get_length() const = 0;
151 };
152
153 }} // namespace uhd::rfnoc
fft_magnitude
Definition: fft_block_control.hpp:16
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:22
Definition: build_info.hpp:12
Definition: noc_block_base.hpp:42
fft_shift
Definition: fft_block_control.hpp:14
Definition: config.h:87
fft_direction
Definition: fft_block_control.hpp:15
Definition: fft_block_control.hpp:41
UHD_INLINE size_t shift(const soft_reg_field_t field)
Definition: soft_register.hpp:80
