uhd::rfnoc::fft_block_control Class Referenceabstract
#include <uhd/rfnoc/fft_block_control.hpp>
Inheritance diagram for uhd::rfnoc::fft_block_control:
virtual void set_direction (const fft_direction direction)=0
virtual fft_direction get_direction () const =0
virtual void set_magnitude (const fft_magnitude magnitude)=0
virtual fft_magnitude get_magnitude () const =0
virtual void set_shift_config (const fft_shift shift)=0
virtual fft_shift get_shift_config () const =0
virtual void set_scaling (const uint16_t scaling)=0
virtual uint16_t get_scaling () const =0
virtual void set_length (const size_t length)=0
virtual size_t get_length () const =0
register_iface & regs ()
static const uint32_t REG_RESET_ADDR
static const uint32_t REG_LENGTH_LOG2_ADDR
static const uint32_t REG_MAGNITUDE_OUT_ADDR
static const uint32_t REG_DIRECTION_ADDR
static const uint32_t REG_SCALING_ADDR
static const uint32_t REG_SHIFT_CONFIG_ADDR
FFT Block Control Class
The FFT block is an RFNoC block that accepts signed complex 16-bit data at its input and computes the forward or reverse FFT of the input data, outputting signed complex 16-bit data at its output. The output data may be configured as complex, magnitude, or mag-squared values, its spectrum shifted and/or reversed, and scaled by a scaled factor.
The FFT length is configured via the length parameter, up to a maximum of 2048 samples. The FFT IP requires a power-of-two number of samples; the length will be coerced to the closest power of two which is smaller than length. The block will output packets of the same length in the desired format as configured via the API.
◆ get_direction()
virtual fft_direction uhd::rfnoc::fft_block_control::get_direction ( ) const
Get the FFT direction
Returns the current direction of the FFT.
FFT direction
◆ get_length()
virtual size_t uhd::rfnoc::fft_block_control::get_length ( ) const
Get the length of the FFT
Returns the current length of the FFT.
Current FFT length
◆ get_magnitude()
virtual fft_magnitude uhd::rfnoc::fft_block_control::get_magnitude ( ) const
Get the format of the returned FFT output data
Returns the current output format of the FFT data.
Format of the returned FFT output data
◆ get_scaling()
virtual uint16_t uhd::rfnoc::fft_block_control::get_scaling ( ) const
Get the scaling schedule for the FFT block
Returns the current scaling schedule for the FFT block.
Scaling schedule for the FFT block
◆ get_shift_config()
virtual fft_shift uhd::rfnoc::fft_block_control::get_shift_config ( ) const
Get the shift configuration of the output FFT data
Returns the current shift configuration of the output FFT data.
Shift configuration of the output FFT data
◆ set_direction()
virtual void uhd::rfnoc::fft_block_control::set_direction ( const fft_direction  direction)
Set the FFT direction
Sets the direction of the FFT, either forward (FORWARD) or inverse (REVERSE).
directionFFT direction
◆ set_length()
virtual void uhd::rfnoc::fft_block_control::set_length ( const size_t  length)
Set the length of the FFT
Sets the length of the FFT in number of samples. Note that the FFT IP requires a power-of-two number of samples; the incoming value will be coerced to the closest smaller power of two.
lengthDesired FFT length
◆ set_magnitude()
virtual void uhd::rfnoc::fft_block_control::set_magnitude ( const fft_magnitude  magnitude)
Set the format of the returned FFT output data
Sets the format in which the FFT output data is returned. The following formats are supported:
* amplitude/phase data (COMPLEX)
* magnitude data (MAGNITUDE)
* mag-squared data (MAGNITUDE_SQUARED)
magnitudeFormat of the returned FFT output data
◆ set_scaling()
virtual void uhd::rfnoc::fft_block_control::set_scaling ( const uint16_t  scaling)
Set the scaling schedule for the FFT block
Sets the scaling for each stage of the FFT. This value maps directly to the scale schedule field in the configuration channel data that is passed to the Xilinx AXI FFT IP. For more information on the format of this data, see Xilinx document PG109, Fast Fourier Transform LogiCORE IP Product Guide.
scalingScaling schedule for the FFT block
◆ set_shift_config()
virtual void uhd::rfnoc::fft_block_control::set_shift_config ( const fft_shift  shift)
Set the shift configuration of the output FFT data
Sets how the FFT output data is shifted (to get the zero frequency bin to the center of the output data). The following output data shift configurations are supported:
* Negative frequencies first, then positive frequencies (NORMAL)
* Positive frequencies first, then negative frequencies (REVERSE)
* Bypass the shift altogether, leaving the zero frequency bin
  returned first (NATURAL).
shiftConfiguration for shifting FFT output data
◆ REG_DIRECTION_ADDR
const uint32_t uhd::rfnoc::fft_block_control::REG_DIRECTION_ADDR
◆ REG_LENGTH_LOG2_ADDR
const uint32_t uhd::rfnoc::fft_block_control::REG_LENGTH_LOG2_ADDR
◆ REG_MAGNITUDE_OUT_ADDR
const uint32_t uhd::rfnoc::fft_block_control::REG_MAGNITUDE_OUT_ADDR
◆ REG_RESET_ADDR
const uint32_t uhd::rfnoc::fft_block_control::REG_RESET_ADDR
◆ REG_SCALING_ADDR
const uint32_t uhd::rfnoc::fft_block_control::REG_SCALING_ADDR
◆ REG_SHIFT_CONFIG_ADDR
const uint32_t uhd::rfnoc::fft_block_control::REG_SHIFT_CONFIG_ADDR
