metadata.hpp
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.hpp>
11 #include <uhd/types/time_spec.hpp>
12 #include <stdint.h>
13 #include <string>
14
15 namespace uhd {
16
23 {
26  {
27  reset();
28  }
29
31  void reset()
32  {
33  has_time_spec = false;
34  time_spec = time_spec_t(0.0);
35  more_fragments = false;
36  fragment_offset = 0;
37  start_of_burst = false;
38  end_of_burst = false;
39  eov_positions = nullptr;
40  eov_positions_size = 0;
41  eov_positions_count = 0;
42  error_code = ERROR_CODE_NONE;
43  out_of_sequence = false;
44  }
45
48
51
60
67
70
73
90  size_t* eov_positions;
92
98
115  ERROR_CODE_NONE = 0x0,
117  ERROR_CODE_TIMEOUT = 0x1,
119  ERROR_CODE_LATE_COMMAND = 0x2,
121  ERROR_CODE_BROKEN_CHAIN = 0x4,
131  ERROR_CODE_OVERFLOW = 0x8,
133  ERROR_CODE_ALIGNMENT = 0xc,
135  ERROR_CODE_BAD_PACKET = 0xf
136  } error_code;
137
141
148  std::string to_pp_string(bool compact = true) const;
149
154  std::string strerror(void) const;
155 };
156
163 {
170
173
176
179
189  size_t* eov_positions = nullptr;
190  size_t eov_positions_size = 0;
191
196  tx_metadata_t(void);
197 };
198
203 {
205  size_t channel;
206
209
212
218  EVENT_CODE_BURST_ACK = 0x1,
220  EVENT_CODE_UNDERFLOW = 0x2,
222  EVENT_CODE_SEQ_ERROR = 0x4,
224  EVENT_CODE_TIME_ERROR = 0x8,
226  EVENT_CODE_UNDERFLOW_IN_PACKET = 0x10,
228  EVENT_CODE_SEQ_ERROR_IN_BURST = 0x20,
230  EVENT_CODE_USER_PAYLOAD = 0x40
231  } event_code;
232
236  uint32_t user_payload[4];
237 };
238
239 } // namespace uhd
time_spec_t time_spec
Time of the first sample.
Definition: metadata.hpp:50
bool end_of_burst
Definition: metadata.hpp:178
Definition: metadata.hpp:172
void reset()
Reset values.
Definition: metadata.hpp:31
Definition: time_spec.hpp:28
Definition: metadata.hpp:91
bool has_time_spec
Has time specification?
Definition: metadata.hpp:208
rx_metadata_t()
Default constructor.
Definition: metadata.hpp:25
size_t fragment_offset
Definition: metadata.hpp:66
event_code_t
Definition: metadata.hpp:216
Definition: metadata.hpp:22
Definition: metadata.hpp:162
Definition: build_info.hpp:12
bool has_time_spec
Definition: metadata.hpp:169
bool start_of_burst
Start of burst will be true for the first packet in the chain.
Definition: metadata.hpp:69
error_code_t
Definition: metadata.hpp:113
bool start_of_burst
Definition: metadata.hpp:175
bool has_time_spec
Definition: metadata.hpp:47
Definition: config.h:87
Definition: metadata.hpp:202
size_t channel
The channel number in a mimo configuration.
Definition: metadata.hpp:205
size_t * eov_positions
Definition: metadata.hpp:90
bool more_fragments
Definition: metadata.hpp:59
bool end_of_burst
End of burst will be true for the last packet in the chain.
Definition: metadata.hpp:72
When the async event occurred.
Definition: metadata.hpp:211
size_t eov_positions_count
Definition: metadata.hpp:97
bool out_of_sequence
Definition: metadata.hpp:140
