Loading [MathJax]/jax/output/HTML-CSS/config.js
uhd::rx_metadata_t Struct Reference
enum  error_code_t {
  ERROR_CODE_NONE = 0x0, ERROR_CODE_TIMEOUT = 0x1, ERROR_CODE_LATE_COMMAND = 0x2, ERROR_CODE_BROKEN_CHAIN = 0x4,
  ERROR_CODE_OVERFLOW = 0x8, ERROR_CODE_ALIGNMENT = 0xc, ERROR_CODE_BAD_PACKET = 0xf
 rx_metadata_t ()
 Default constructor. More...
void reset ()
 Reset values. More...
std::string to_pp_string (bool compact=true) const
std::string strerror (void) const
Public Attributes
bool has_time_spec
 Has time specification? More...
time_spec_t time_spec
 Time of the first sample. More...
bool more_fragments
size_t fragment_offset
bool start_of_burst
 Start of burst will be true for the first packet in the chain. More...
bool end_of_burst
 End of burst will be true for the last packet in the chain. More...
size_t * eov_positions
size_t eov_positions_size
size_t eov_positions_count
enum uhd::rx_metadata_t::error_code_t error_code
bool out_of_sequence
◆ error_code_t
  • none
  • late command
  • broken chain
  • overflow
Enumerator
ERROR_CODE_NONE
No error associated with this metadata.
ERROR_CODE_TIMEOUT
No packet received, implementation timed-out.
A stream command was issued in the past.
Expected another stream command.
ERROR_CODE_OVERFLOW
An internal receive buffer has filled or a sequence error has been detected. So, why is this overloaded? Simple: legacy support. It would have been much cleaner to create a separate error code for a sequence error, but that would have broken legacy applications. So, the out_of_sequence flag was added to differentiate between the two error cases. In either case, data is missing between this time_spec and the and the time_spec of the next successful receive.
Multi-channel alignment failed.
The packet could not be parsed.
◆ rx_metadata_t()
uhd::rx_metadata_t::rx_metadata_t ( )
◆ reset()
void uhd::rx_metadata_t::reset ( )
Reset values.
◆ strerror()
std::string uhd::rx_metadata_t::strerror ( void  ) const
Similar to C's strerror() function, creates a std::string describing the error code.
a printable string representing the error.
◆ to_pp_string()
std::string uhd::rx_metadata_t::to_pp_string ( bool  compact = true) const
Convert a rx_metadata_t into a pretty print string.
compactSet to false for a more verbose output.
a printable string representing the metadata.
◆ end_of_burst
bool uhd::rx_metadata_t::end_of_burst
◆ eov_positions
size_t* uhd::rx_metadata_t::eov_positions
If this pointer is not null, it specifies the address of an array of size_ts into which the sample offset relative to the beginning of a call to recv() of each vector (as denoted by packets with the eov header byte set) will be written.
The caller is responsible for allocating and deallocating the storage for the array and for indicating the maximum number of elements in the array via the eov_positions_size value below.
Upon return from recv(), eov_positions_count will be updated to indicate the number of valid entries written to the end_of_vector_positions array. It shall never exceed the value of eov_positions_size. However, if in the process of recv(), storage for new positions is exhausted, then recv() shall return.
◆ eov_positions_count
size_t uhd::rx_metadata_t::eov_positions_count
Upon return from recv(), holds the number of end-of-vector indications in the eov_positions array.
◆ eov_positions_size
size_t uhd::rx_metadata_t::eov_positions_size
◆ error_code
enum uhd::rx_metadata_t::error_code_t uhd::rx_metadata_t::error_code
◆ fragment_offset
size_t uhd::rx_metadata_t::fragment_offset
◆ has_time_spec
bool uhd::rx_metadata_t::has_time_spec
◆ more_fragments
bool uhd::rx_metadata_t::more_fragments
◆ out_of_sequence
bool uhd::rx_metadata_t::out_of_sequence
Out of sequence. The transport has either dropped a packet or received data out of order.
◆ start_of_burst
bool uhd::rx_metadata_t::start_of_burst
◆ time_spec
time_spec_t uhd::rx_metadata_t::time_spec
