uhd::cast Namespace Reference
Functions
template<typename T >
T hexstr_cast (const std::string &in)
 Convert a hexadecimal string into a value. More...
T fromstr_cast (const std::string &in)
template<typename data_t >
data_t from_str (const std::string &)
 Generic cast-from-string function. More...
template<>
UHD_API bool from_str (const std::string &val)
 Specialization of uhd::cast::from_str() for Boolean values. More...
template<>
UHD_API double from_str (const std::string &val)
 Specialization of uhd::cast::from_str() for double-precision values. More...
template<>
UHD_API int from_str (const std::string &val)
 Specialization of uhd::cast::from_str() for integer values. More...
template<>
UHD_API std::string from_str (const std::string &val)
 Specialization of uhd::cast::from_str() for strings. More...
Function Documentation
◆ from_str() [1/5]
data_t uhd::cast::from_str ( const std::string &  )
◆ from_str() [2/5]
template<>
UHD_API bool uhd::cast::from_str ( const std::string &  )
◆ from_str() [3/5]
template<>
UHD_API double uhd::cast::from_str ( const std::string &  )
◆ from_str() [4/5]
template<>
UHD_API int uhd::cast::from_str ( const std::string &  )
◆ from_str() [5/5]
template<>
UHD_API std::string uhd::cast::from_str ( const std::string &  )
◆ fromstr_cast()
T uhd::cast::fromstr_cast ( const std::string &  in)
Convert hexadecimal, decimal, octal or other strings that support the >> operator into a value depending on the prefix.
◆ hexstr_cast()
T uhd::cast::hexstr_cast ( const std::string &  in)
