Loading [MathJax]/jax/output/HTML-CSS/config.js
uhd::rfnoc::action_info Struct Reference
#include <uhd/rfnoc/actions.hpp>
Inheritance diagram for uhd::rfnoc::action_info:
uhd::rfnoc::rx_event_action_info uhd::rfnoc::stream_cmd_action_info uhd::rfnoc::tx_event_action_info
using sptr = std::shared_ptr< action_info >
virtual ~action_info ()
static sptr make (const std::string &key="", const uhd::device_addr_t &args=uhd::device_addr_t(""))
 Factory function. More...
Public Attributes
const size_t id
 A unique counter for this action. More...
std::string key
 A string identifier for this action. More...
std::vector< uint8_t > payload
 An arbitrary payload. It is up to consumers and producers to. More...
uhd::device_addr_t args
 A dictionary of key-value pairs. May be used as desired. More...
 action_info (const std::string &key, const uhd::device_addr_t &args=uhd::device_addr_t(""))
Container for an action
In the RFNoC context, an action is comparable to a command. Nodes in the graph can send each other actions. action_info is the payload of such an action message. Nodes pass shared pointers to action_info objects between each other to avoid costly copies of large action_info objects.
using uhd::rfnoc::action_info::sptr = std::shared_ptr<action_info>
◆ ~action_info()
virtual uhd::rfnoc::action_info::~action_info ( )
◆ action_info()
uhd::rfnoc::action_info::action_info ( const std::string &  key,
const uhd::device_addr_t args = uhd::device_addr_t("")
◆ make()
static sptr uhd::rfnoc::action_info::make ( const std::string &  key = "",
Factory function.
◆ args
uhd::device_addr_t uhd::rfnoc::action_info::args
◆ id
const size_t uhd::rfnoc::action_info::id
◆ key
std::string uhd::rfnoc::action_info::key
◆ payload
std::vector<uint8_t> uhd::rfnoc::action_info::payload
