subdev_spec.h
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.h>
11 #include <uhd/error.h>
12
13 #include <stdbool.h>
14
16 typedef struct
17 {
18  // Daughterboard slot name
19  char* db_name;
21  char* sd_name;
23
24 #ifdef __cplusplus
25 # include <uhd/usrp/subdev_spec.hpp>
26 # include <string>
27
28 struct uhd_subdev_spec_t
29 {
30  uhd::usrp::subdev_spec_t subdev_spec_cpp;
31  std::string last_error;
32 };
33
34 extern "C" {
35 #else
36 struct uhd_subdev_spec_t;
37 #endif
38
40
46 typedef struct uhd_subdev_spec_t* uhd_subdev_spec_handle;
47
50
53  const uhd_subdev_spec_pair_t* second,
54  bool* result_out);
55
57 UHD_API uhd_error uhd_subdev_spec_make(uhd_subdev_spec_handle* h, const char* markup);
58
60
64 UHD_API uhd_error uhd_subdev_spec_free(uhd_subdev_spec_handle* h);
65
67 UHD_API uhd_error uhd_subdev_spec_size(uhd_subdev_spec_handle h, size_t* size_out);
68
70 UHD_API uhd_error uhd_subdev_spec_push_back(uhd_subdev_spec_handle h, const char* markup);
71
74  uhd_subdev_spec_handle h, size_t num, uhd_subdev_spec_pair_t* subdev_spec_pair_out);
75
78  uhd_subdev_spec_handle h, char* pp_string_out, size_t strbuffer_len);
79
82  uhd_subdev_spec_handle h, char* string_out, size_t strbuffer_len);
83
86  uhd_subdev_spec_handle h, char* error_out, size_t strbuffer_len);
87
88 #ifdef __cplusplus
89 }
90
91 UHD_API uhd::usrp::subdev_spec_pair_t uhd_subdev_spec_pair_c_to_cpp(
92  const uhd_subdev_spec_pair_t* subdev_spec_pair_c);
93
94 UHD_API void uhd_subdev_spec_pair_cpp_to_c(
95  const uhd::usrp::subdev_spec_pair_t& subdev_spec_pair_cpp,
96  uhd_subdev_spec_pair_t* subdev_spec_pair_c);
97 #endif
UHD_API uhd_error uhd_subdev_spec_at(uhd_subdev_spec_handle h, size_t num, uhd_subdev_spec_pair_t *subdev_spec_pair_out)
Get the subdevice specification at the given index.
UHD_API uhd_error uhd_subdev_spec_pairs_equal(const uhd_subdev_spec_pair_t *first, const uhd_subdev_spec_pair_t *second, bool *result_out)
Check to see if two subdevice specifications are equal.
char * sd_name
Subdevice name.
Definition: subdev_spec.h:21
UHD_API uhd_error uhd_subdev_spec_to_pp_string(uhd_subdev_spec_handle h, char *pp_string_out, size_t strbuffer_len)
Get a string representation of the given list.
UHD_API uhd_error uhd_subdev_spec_make(uhd_subdev_spec_handle *h, const char *markup)
Create a handle for a list of subdevice specifications.
UHD_API uhd_error uhd_subdev_spec_last_error(uhd_subdev_spec_handle h, char *error_out, size_t strbuffer_len)
Get the last error recorded by the given handle.
UHD_API uhd_error uhd_subdev_spec_free(uhd_subdev_spec_handle *h)
Safely destroy a subdevice specification handle.
uhd_error
UHD error codes.
Definition: error.h:20
Definition: subdev_spec.hpp:20
Subdevice specification.
Definition: subdev_spec.h:16
UHD_API uhd_error uhd_subdev_spec_size(uhd_subdev_spec_handle h, size_t *size_out)
Check how many subdevice specifications are in this list.
char * db_name
Definition: subdev_spec.h:19
UHD_API uhd_error uhd_subdev_spec_to_string(uhd_subdev_spec_handle h, char *string_out, size_t strbuffer_len)
Get a markup string representation of the given list.
Definition: config.h:87
UHD_API uhd_error uhd_subdev_spec_pair_free(uhd_subdev_spec_pair_t *subdev_spec_pair)
Safely destroy any memory created in the generation of a uhd_subdev_spec_pair_t.
Definition: subdev_spec.hpp:59
struct uhd_subdev_spec_t * uhd_subdev_spec_handle
A C-level interface for working with a list of subdevice specifications.
Definition: subdev_spec.h:46
UHD_API uhd_error uhd_subdev_spec_push_back(uhd_subdev_spec_handle h, const char *markup)
Add a subdevice specification to this list.
