11 #include <uhdlib/utils/narrow.hpp>    13 #include <type_traits>    17 namespace uhd {
namespace rfnoc {
    22     typedef std::shared_ptr<traffic_counter>
sptr;
    23     typedef std::function<void(const uint32_t addr, const uint32_t data)>
write_reg_fn_t;
    28         write_reg_fn_t write_reg_fn,
    29         read_reg_fn_t read_reg_fn)
    30         : _write_reg_fn(write_reg_fn), _read_reg_fn(read_reg_fn)
    32         const uint32_t id_reg_offset        = 0;
    33         const uint32_t first_counter_offset = 1;
    34         const uint64_t traffic_counter_id   = 0x712AFF1C00000000ULL;
    37         const uint64_t
id = _read_reg_fn(id_reg_offset);
    40         if (
id == traffic_counter_id) {
    41             tree->create<
bool>(root_path /
"traffic_counter/enable")
    42                 .add_coerced_subscriber([
this](
const bool enable) {
    43                     uint32_t val = enable ? 1 : 0;
    44                     return _write_reg_fn(0, val);
    48             const char* counters[] = {
"bus_clock_ticks",
    49                 "xbar_to_shell_xfer_count",
    50                 "xbar_to_shell_pkt_count",
    51                 "shell_to_xbar_xfer_count",
    52                 "shell_to_xbar_pkt_count",
    53                 "shell_to_ce_xfer_count",
    54                 "shell_to_ce_pkt_count",
    55                 "ce_to_shell_xfer_count",
    56                 "ce_to_shell_pkt_count"};
    58             for (
size_t i = 0; i < std::extent<decltype(counters)>::value; i++) {
    59                 tree->create<uint64_t>(root_path /
"traffic_counter" / counters[i])
    60                     .set_publisher([
this, i, first_counter_offset]() {
    62                             uhd::narrow_cast<uint32_t>(i) + first_counter_offset);
    69     write_reg_fn_t _write_reg_fn;
    70     read_reg_fn_t _read_reg_fn;
Definition: property_tree.hpp:205
Definition: traffic_counter.hpp:19
std::function< uint64_t(const uint32_t addr)> read_reg_fn_t
Definition: traffic_counter.hpp:24
Definition: build_info.hpp:12
std::shared_ptr< traffic_counter > sptr
Definition: traffic_counter.hpp:22
std::function< void(const uint32_t addr, const uint32_t data)> write_reg_fn_t
Definition: traffic_counter.hpp:23
traffic_counter(uhd::property_tree::sptr tree, uhd::fs_path root_path, write_reg_fn_t write_reg_fn, read_reg_fn_t read_reg_fn)
Definition: traffic_counter.hpp:26
Definition: property_tree.hpp:223
