|   | device_addr_t (const std::string &args="") |
|   | device_addr_t (const char *args) |
|   | device_addr_t (const std::map< std::string, std::string > &info) |
| std::string  | to_pp_string (void) const |
| std::string  | to_string (void) const |
| template<typename T >  |
| T  | cast (const std::string &key, const T &def) const |
|   | dict (void) |
|   | dict (InputIterator first, InputIterator last) |
| std::size_t  | size (void) const |
| std::vector< std::string >  | keys (void) const |
| std::vector< std::string >  | vals (void) const |
| bool  | has_key (const std::string &key) const |
| const std::string &  | get (const std::string &key, const std::string &other) const |
| const std::string &  | get (const std::string &key) const |
| void  | set (const std::string &key, const std::string &val) |
| const std::string &  | operator[] (const std::string &key) const |
| std::string &  | operator[] (const std::string &key) |
| bool  | operator== (const dict< std::string, std::string > &other) const |
| bool  | operator!= (const dict< std::string, std::string > &other) const |
| std::string  | pop (const std::string &key) |
| void  | update (const dict< std::string, std::string > &new_dict, bool fail_on_conflict=true) |
|   | operator std::map< std::string, std::string > () const |
- Ex, to find a usrp2: my_dev_addr["addr"] = [resolvable_hostname_or_ip]
- Ex: addr=192.168.10.2
- Ex: addr=192.168.10.2, recv_buff_size=1e6
