 Public Types | |
| typedef std::shared_ptr< i2c_iface > | sptr |
| virtual | ~i2c_iface (void) |
| i2c_iface::sptr | eeprom16 (void) |
| Create an i2c_iface than can talk to 16 bit addressable EEPROMS.  More... | |
| virtual void | write_i2c (uint16_t addr, const byte_vector_t &buf)=0 |
| virtual byte_vector_t | read_i2c (uint16_t addr, size_t num_bytes)=0 |
| virtual void | write_eeprom (uint16_t addr, uint16_t offset, const byte_vector_t &buf) |
| virtual byte_vector_t | read_eeprom (uint16_t addr, uint16_t offset, size_t num_bytes) |
| typedef std::shared_ptr<i2c_iface> uhd::i2c_iface::sptr |
  virtual |
| i2c_iface::sptr uhd::i2c_iface::eeprom16 | ( | void | ) |
  virtual |
Read bytes from an eeprom.
| addr | the address |
| offset | byte offset |
| num_bytes | number of bytes to read |
Read bytes over the i2c.
  virtual |
Write bytes to an eeprom.
| buf | the vector of bytes |
Write bytes over the i2c.
