|   | block_id_t () |
|   | block_id_t (const std::string &block_str) |
|   | block_id_t (const size_t device_no, const std::string &block_name, const size_t block_ctr=0) |
| std::string  | to_string () const |
|   | Return a string like this: "0/FFT#1" (includes all components, if set)  More...
| bool  | match (const std::string &block_str) |
|   | Check if block_str matches this block.  More...
| std::string  | get () const |
|   | Short for to_string()  More...
| std::string  | get_local () const |
|   | Like get(), but only returns the local part ("FFT#1")  More...
| uhd::fs_path  | get_tree_root () const |
|   | Returns the property tree root for this block (e.g. "/mboards/0/xbar/FFT#1/")  More...
| size_t  | get_device_no () const |
|   | Return device number.  More...
| size_t  | get_block_count () const |
|   | Return block count.  More...
| std::string  | get_block_name () const |
|   | Return block name.  More...
| bool  | set (const std::string &new_name) |
|   | Set from string such as "0/FFT#1", "FFT#0", ...  More...
| bool  | set (const size_t device_no, const std::string &block_name, const size_t block_ctr=0) |
|   | Sets from individual components, like calling set_device_no(), set_block_name()  More...
| void  | set_device_no (size_t device_no) |
|   | Set the device number.  More...
| bool  | set_block_name (const std::string &block_name) |
|   | Set the block name. Will return false if invalid block string.  More...
| void  | set_block_count (size_t count) |
|   | Set the block count.  More...
| block_id_t  | operator= (const std::string &new_name) |
|   | Assignment: Works like set(std::string)  More...
| bool  | operator== (const block_id_t &block_id) const |
| bool  | operator!= (const block_id_t &block_id) const |
| bool  | operator< (const block_id_t &block_id) const |
| bool  | operator> (const block_id_t &block_id) const |
| bool  | operator== (const std::string &block_id_str) const |
|   | Check if a string matches the entire block ID (not like match())  More...
| bool  | operator== (const char *block_id_str) const |
|   | operator std::string () const |
|   | Type-cast operator does the same as to_string()  More...
| block_id_t  | operator++ () |
|   | Increment the block count ("FFT#1" -> "FFT_2")  More...
| block_id_t  | operator++ (int) |
Identifies an RFNoC block.
An RFNoC block ID is a string such as: 0/FFT#1
The rules for formatting such a string are:
DEVICE/BLOCKNAME#COUNTER
DEVICE: Identifies the device (usually the motherboard index) BLOCKNAME: A name given to this block COUNTER: If is are more than one block with a BLOCKNAME, this counts up.
So, 0/FFT#1 means we're addressing the second block called FFT on the first device.
This class can represent these block IDs.
