A class that represents a complete multi-hop management transaction.
More...
◆ mgmt_payload() [1/3]
| uhd::rfnoc::chdr::mgmt_payload::mgmt_payload |
default |
◆ mgmt_payload() [2/3]
const mgmt_payload & |
rhs | ) |
default |
◆ mgmt_payload() [3/3]
mgmt_payload && |
rhs | ) |
default |
◆ add_hop()
| void uhd::rfnoc::chdr::mgmt_payload::add_hop |
const mgmt_hop_t & |
hop | ) |
inline |
Add a management hop to this transaction.
◆ deserialize() [1/2]
| void uhd::rfnoc::chdr::mgmt_payload::deserialize |
const uint64_t * |
buff, |
size_t |
buff_size, |
const std::function< uint64_t(uint64_t)> & |
conv_byte_order |
Deserialize the payload from a uint64_t buffer
- Parameters
| buff | Buffer to deserialize the payload from |
| buff_size | Number of elements in the buffer |
| conv_byte_order | Byte order converter function (buffer to host endianness) |
◆ deserialize() [2/2]
const uint64_t * |
buff, |
size_t |
buff_size |
inline |
Deserialize the payload from a uint64_t buffer (no conversion function)
- Parameters
◆ get_chdr_w()
| chdr_w_t uhd::rfnoc::chdr::mgmt_payload::get_chdr_w |
const |
inline |
Return the CHDR_W for this transaction.
◆ get_hop()
| const mgmt_hop_t& uhd::rfnoc::chdr::mgmt_payload::get_hop |
size_t |
i | ) |
const |
inline |
Get the n'th hop in the transaction.
◆ get_length()
| size_t uhd::rfnoc::chdr::mgmt_payload::get_length |
const |
Get the serialized size of this payload in 64 bit words.
◆ get_num_hops()
| size_t uhd::rfnoc::chdr::mgmt_payload::get_num_hops |
const |
inline |
Get the number of management hops in this hop.
◆ get_proto_ver()
| uint16_t uhd::rfnoc::chdr::mgmt_payload::get_proto_ver |
const |
inline |
Return the protocol version for this transaction.
◆ get_size_bytes()
| size_t uhd::rfnoc::chdr::mgmt_payload::get_size_bytes |
const |
inline |
◆ get_src_epid()
| sep_id_t uhd::rfnoc::chdr::mgmt_payload::get_src_epid |
const |
inline |
Return the source EPID for this transaction.
◆ hops_to_string()
| std::string uhd::rfnoc::chdr::mgmt_payload::hops_to_string |
const |
Return a string representaiton of the hops contained by this object.
◆ operator=()
◆ operator==()
| bool uhd::rfnoc::chdr::mgmt_payload::operator== |
rhs | ) |
const |
◆ pop_hop()
| mgmt_hop_t uhd::rfnoc::chdr::mgmt_payload::pop_hop |
inline |
Pop the first hop of the transaction and return it.
◆ populate_header()
| void uhd::rfnoc::chdr::mgmt_payload::populate_header |
chdr_header & |
header | ) |
const |
Populate the header for this type of packet.
◆ serialize() [1/2]
| size_t uhd::rfnoc::chdr::mgmt_payload::serialize |
uint64_t * |
buff, |
size_t |
max_size_bytes, |
conv_byte_order |
| const |
Serialize the payload to a uint64_t buffer.
◆ serialize() [2/2]
uint64_t * |
buff, |
size_t |
max_size_bytes |
| const |
inline |
Serialize the payload to a uint64_t buffer (no conversion function)
◆ set_chdr_w()
| void uhd::rfnoc::chdr::mgmt_payload::set_chdr_w |
chdr_w_t |
chdr_w | ) |
inline |
Set the CHDR_W for this transaction.
◆ set_header()
| void uhd::rfnoc::chdr::mgmt_payload::set_header |
sep_id_t |
src_epid, |
uint16_t |
protover, |
chdr_w_t |
chdr_w |
inline |
◆ set_proto_ver()
| void uhd::rfnoc::chdr::mgmt_payload::set_proto_ver |
uint16_t |
proto_ver | ) |
inline |
Set the protocol version for this transaction.
◆ set_src_epid()
| void uhd::rfnoc::chdr::mgmt_payload::set_src_epid |
sep_id_t |
src_epid | ) |
inline |
Set the source EPID for this transaction.
◆ to_string()
| std::string uhd::rfnoc::chdr::mgmt_payload::to_string |
const |
Return a string representation of this object.
