23 namespace uhd {
namespace usrp {
    56     typedef std::shared_ptr<dboard_iface>
sptr;
    75     enum aux_adc_t { AUX_ADC_A = int(
'a'), AUX_ADC_B = int(
'b') };
    87     virtual special_props_t get_special_props(
void) = 0;
    96     virtual void write_aux_dac(
unit_t unit,
aux_dac_t which_dac,
double value) = 0;
   114     virtual void set_pin_ctrl(
unit_t unit, uint32_t value, uint32_t
mask = 0xffff) = 0;
   122     virtual uint32_t get_pin_ctrl(
unit_t unit) = 0;
   132     virtual void set_atr_reg(
   133         unit_t unit, atr_reg_t reg, uint32_t value, uint32_t
mask = 0xffff) = 0;
   142     virtual uint32_t get_atr_reg(
unit_t unit, atr_reg_t reg) = 0;
   151     virtual void set_gpio_ddr(
mask = 0xffff) = 0;
   159     virtual uint32_t get_gpio_ddr(
unit_t unit) = 0;
   168     virtual void set_gpio_out(
mask = 0xffff) = 0;
   176     virtual uint32_t get_gpio_out(
unit_t unit) = 0;
   184     virtual uint32_t read_gpio(
unit_t unit) = 0;
   194     virtual void write_spi(
   206     virtual uint32_t read_write_spi(
   215     virtual void set_clock_rate(
unit_t unit,
double rate) = 0;
   223     virtual double get_clock_rate(
unit_t unit) = 0;
   231     virtual std::vector<double> get_clock_rates(
unit_t unit) = 0;
   239     virtual void set_clock_enabled(
unit_t unit,
bool enb) = 0;
   248     virtual double get_codec_rate(
unit_t unit) = 0;
   257     virtual void set_fe_connection(
unit_t unit,
   258         const std::string& fe_name,
   284     virtual void sleep(
const std::chrono::nanoseconds& time);
   292         std::function<
void(uint32_t, uint32_t)>,
   293         std::function<uint32_t(uint32_t)>)
aux_adc_t
Definition: dboard_iface.hpp:75
Definition: serial.hpp:35
~dboard_iface(void) override
Definition: dboard_iface.hpp:79
uhd::usrp::gpio_atr::gpio_atr_reg_t atr_reg_t
Definition: dboard_iface.hpp:77
Definition: time_spec.hpp:28
aux_dac_t
Definition: dboard_iface.hpp:67
Definition: build_info.hpp:12
Definition: dboard_iface.hpp:53
bool soft_clock_divider
Definition: dboard_iface.hpp:34
Definition: serial.hpp:82
Definition: fe_connection.hpp:16
gpio_atr_reg_t
Definition: gpio_defs.hpp:12
std::shared_ptr< dboard_iface > sptr
Definition: dboard_iface.hpp:56
Definition: config.h:87
Definition: soft_register.hpp:86
virtual void define_custom_register_space(const uint32_t, const uint32_t, std::function< void(uint32_t, uint32_t)>, std::function< uint32_t(uint32_t)>)
Definition: dboard_iface.hpp:290
Definition: dboard_iface.hpp:57
Definition: dboard_iface.hpp:26
virtual bool has_set_fe_connection(const unit_t)
Definition: dboard_iface.hpp:263
unit_t
bool mangle_i2c_addrs
Definition: dboard_iface.hpp:44
