Namespaces | |
| cal | |
| gpio_atr | |
| zbx | |
Classes | |
| struct | component_file_t |
| class | dboard_base |
| struct | dboard_eeprom_t |
| class | dboard_id_t |
| class | dboard_iface |
| struct | dboard_iface_special_props_t |
| Special properties that differentiate this daughterboard slot.  More... | |
| class | dboard_manager |
| class | fe_connection_t |
| class | multi_usrp |
| class | rx_dboard_base |
| struct | subdev_spec_pair_t |
| class | subdev_spec_t |
| class | tx_dboard_base |
| class | xcvr_dboard_base |
Typedefs | |
| typedef std::vector< component_file_t > | component_files_t |
| typedef uhd::dict< std::string, std::string > | mboard_eeprom_t |
Functions | |
| UHD_API bool | operator== (const dboard_id_t &lhs, const dboard_id_t &rhs) |
| UHD_API bool | operator== (const fe_connection_t &lhs, const fe_connection_t &rhs) |
| UHD_API bool | operator== (const subdev_spec_pair_t &, const subdev_spec_pair_t &) |
| overloaded comparison operator for subdev_spec_pair_t  More... | |
| typedef std::vector<component_file_t> uhd::usrp::component_files_t |
| typedef uhd::dict<std::string, std::string> uhd::usrp::mboard_eeprom_t |
The motherboard EEPROM object.
The specific implementation knows how to read and write the EEPROM for various USRPs. By itself, this class is nothing but a thin wrapper around a string -> string dictionary.
Note that writing to an object of type mboard_eeprom_t does not actually write to the EEPROM. Devices have their own APIs to read/write from the EEPROM chips themselves. Most devices will write the EEPROM itself when the according property is updated.
| UHD_API bool uhd::usrp::operator== | ( | const subdev_spec_pair_t & | , |
| const subdev_spec_pair_t & | |||
| UHD_API bool uhd::usrp::operator== | ( | const dboard_id_t & | lhs, |
| const dboard_id_t & | rhs | ||
Comparator operator overloaded for dboard ids. The boost::equality_comparable provides the !=.
| lhs | the dboard id to the left of the operator |
| rhs | the dboard id to the right of the operator |
| UHD_API bool uhd::usrp::operator== | ( | const fe_connection_t & | lhs, |
| const fe_connection_t & | rhs | ||
Comparator operator overloaded for fe_connection_t. The boost::equality_comparable provides the !=.
| lhs | the fe_connection_t to the left of the operator |
| rhs | the fe_connection_t to the right of the operator |
