A meta-range object holds a list of individual ranges.
◆ meta_range_t() [1/3]
          | uhd::meta_range_t::meta_range_t  |
          void  |
A default constructor for an empty meta-range.
◆ meta_range_t() [2/3]
template<typename InputIterator >
          InputIterator  |
          first,  |
          InputIterator  |
          last  |
inline   |
Input iterator constructor: Makes boost::assign::list_of work.
- Parameters
    | first | the begin iterator  |
    | last | the end iterator  |
◆ meta_range_t() [3/3]
          double  |
          start,  |
          double  |
          stop,  |
          double  |
          step = 0  |
A convenience constructor for a single range. A step size of zero implies infinite precision.
- Parameters
    | start | the minimum value for this range  |
    | stop | the maximum value for this range  |
    | step | the step size for this range  |
◆ as_monotonic()
A method for converting an arbitrary meta_range_t into a monotonic meta_range_t which has no overlapping ranges, and where all ranges are sorted.
Requires that all subranges have a step size of zero, or else it throws uhd::value_error.
- Returns
 - a monotonic meta_range_t
◆ clip()
          | double uhd::meta_range_t::clip  |
          double  |
          value,  |
          bool  |
          clip_step = false  |
           |  const |
Clip the target value to a possible range value.
- Parameters
    | value | the value to clip to this range  |
    | clip_step | if true, clip to steps as well  |
- Returns
 - a value that is in one of the ranges
◆ start()
          | double uhd::meta_range_t::start  |
          void  |
           const |
Get the overall start value for this meta-range.
◆ step()
          | double uhd::meta_range_t::step  |
          void  |
           const |
Get the overall step value for this meta-range.
◆ stop()
          | double uhd::meta_range_t::stop  |
          void  |
           const |
Get the overall stop value for this meta-range.
◆ to_pp_string()
          | std::string uhd::meta_range_t::to_pp_string  |
          void  |
           const |
Convert this meta-range to a printable string.
